Network Bridge concept
iifanatic
Community Member
Beginner studying for CCNA exam.
I have a bit of confusion between Bridges.
"Bridges are used to connect network segments"
Do these network segments need to be on the same network?
I mean can a network with 10 hosts on a hub with ip address 172.16.1.15 communicate with another network 192.168.1.2 by connecting a bridge.
With switches, what is the major difference between a bridge and a switch not with respect to functionality but general difference in terms of frame forwarding ..
Do bridges and switches work same EXCEPT bridges have less ports and switches have more?
If someone can avoid this confusion, I would be really grateful to him.
2 Accepted Solutions
Francois Tallet
Level 11
Level 11
My definition of switch is "marketing term for fast bridge"... which technically means "bridge";-)
I guess the only reason why the term was introduced was to push you to upgrade your "old" bridge and buy a new cool device. I think you can challenge anyone who has a clear definition of a switch (vs. a bridge). However, if some CCNA book pretend those are two kind of devices, don't lose points for that!
Francois
Yes, if it doesn't already know where to send the packet (ie when the destination MAC address is not in it's table), it always floods all ports (at least all ports in the same VLAN, if you don't understand it, ignore the VLAN part for the time being about it yet).
You can have multiple MAC addresses on one port, such as if there is a switch/hub on that port, or say a user running virtual machines on a computer. As such, it can never assume it knows all possible MAC addresses on one port, so it always has to flood all ports (when it doesn't know where it is).
Note that it isn't flooding addresses, it is flooding ports, ie it doesn't flood the known addresses, when it reaches the flood stage, it doesn't care about what is already there and that table has no relevance.
5 Replies 5
Francois Tallet
Level 11
Level 11
Francois
meballard
Level 2
Level 2
A switch is a multi-port bridge. A plain bridge has 2 ports, a switch has more than 2 (such as 8, 24, 48, etc).
Beyond that, there isn't an inherent difference between a bridge and a switch.
A bridge only separate collision domains, not network subnets. Both sides of a bridge are part of the same network, so 172.16.1.15 would never be able to communicate with 192.168.1.2 with a regular bridge, a router would be required for that.
Thanks guys.
One more question.
There is a concept of flooding in bridges.
If a bridge doesnt know the destination mac address it will flood all the ports.
Following is the scenario:
4 hosts connected to the bridge. There MAC addresses are as follows:
aaaaHost1 port1
bbbbHost2 port2
ccccHost3 port3
ddddHost4 port4
Host aaaaHost1 communicates with ddddHost4
As it is a new bridge, the bridge enters the entries in the bridging table:
aaaa.host1 port1
cccc.host4 port4
Now bbbbhost2 sends a unknown frame to some destination, will the bridge FLOOD all the ports including the KNOWN addresses above in the table?
If bbbb *sends to* any address other than aaaa and dddd (assuming "cccc.host4 port4" above is a typo), it will flood it, because the only specific destinations it knows are aaaa and dddd.
Paul
