Network designed issue
opnineopnine
Level 7
Level 7
Hi all,
Is there any Cisco designed or best practices, about having 4 nexus 56128, as Core devices?
5 Replies 5
Ganesh Hariharan
Hi all,Is there any Cisco designed or best practices, about having 4 nexus 56128, as Core devices?Thanks557
Design a network is required for thinking w.r.t layered architecture rather on 4 devices.
If you want to design traditional Three tier architecture then there are devices which fits on respective layer like in Core ( High end routing) , Distribution ( Policy based switching) and Access ( fast processing).
Nowadays we design Spine and Leaf architecture for highly scable and for high performance throughput with high density backbone.
Hope that Helps..
-GI
Hello Ganesh,
Is there any pdf o document I can read more about this , and what will you mean with w.r.t?
Thanks.!
You may find some validated designs that you may be interested in the design Zone.Not much information on your post for me to direct you to a specific one but main link is as below.There's a 5500 use case in the data center section
http://www.cisco.com/c/en/us/solutions/enterprise/design-zone/index.html
Cheers
Prabath
***Please rate all the useful posts***
-Prabath
Hello preranda78.
Like I said the customer has the idea to put 4 nexus 56128 in one site, down this will go Fex 2248.  But my question , what will the best practices be with this topology.
thanks
You need to read design guides for this and talk to the customer.
If they want 4 N5ks in a site do they want all 4 as core switches or two as core switches and two as aggregation which would follow the traditional design model or are they looking for a newer design such as the one Ganesh mentions.
If the customer is asking specifically for 4 switches they must have an idea of what they want ie. nobody just randomly picks the number of switches they want, they must have some idea of the design.
Have a look at this link which is for N9K but it gives you some idea of the possible alternatives -
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/guide-c07-730115.html
Jon
