Network error:connection Refused
paulike12
Dear all,
I configured ssh on my router and since the could not login using putty on my LAN or WAN. i was using telnet before i configured ssh.The error message is Network error:connection refused why I try to login.Can anyone help me figure out this error?
7 Replies 7
Mark Malone
You have no key enabled so ssh is disabled
%Please create RSA keys to enable SSH (and of atleast 768 bits for SSH v2).
To generate a key fo the below in conf t mode
crypto key generate rsa ------then hit return type 1024 and return again run --show ip ssh
it should be enabled then
I know this is old, but, it is my exact issue. When I generate the key it says it does, but it appears not to. If I issue crypto key generate rsa modulus 2048 and then to sh ip ssh I get
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc,aes192-cbc,aes256-cbc
MAC Algorithms:hmac-sha1,hmac-sha1-96
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): NONE
I have tried zeroizing and reissuing the key, to no avail. I have a ticket open right now, but so far no love.
Thoughts?
Do you get the same if you try do a 1024 key ?
whats does the show crypto key mypubkey rsa output show ?
when you try this crypto key zeroize rsa does it remove keys?
You have a domain-name/hostname and username set yes can block it as well if not in config
Right now (prior to trying a 1024 key) I get a cisco_idevid_sudi keytype RSA Keys
another showing the proper device name + Domain with keytype RSA_keys - all general purpose
issued zeroize -
one key left which is the cisco idevid
generated keys with 1024 and have the same two keyst again.
I do have a domain name and host name. Also have a local user and pwd on the vty...along with acl, etc. But, it does include the network I'm coming from.
sh ip ssh still says to create a key.
And does the ssh work when you try access the switch from putty can you log in by ssh does it show you as an ssh user with show ssh ?
It might be just a cosmetic bug if the actual ssh is still working
SSH did not work at all.
TAC got it working for me, and it was very simple if correct. I would never have given you the proper info to get it fixed.
Apparently I created the key before I created the key-pair. He did it in the other order and it worked. Not sure I had ever paid attention to the order I was doing it in.
Thanks for reading!
good to know :)
