Showing results forĀ
Search instead forĀ
Did you mean:Ā
Network latency below 1ms
sdasgupta
Level 3
Level 3
Dear All,
If we want Maximum latency among all systems within a given data center should not exceed 1 Ms in any given month.
What are the steps or parameters we should take care
Debabrata Majhi
Dennis Mink
do you mean should not exceed 1ms (milisecond)? or Megasecond?
Please remember to rate useful posts, by clicking on the stars below.
Dear Dennis,
Yes,It is ms(millisecond)
Debabrata Majhi
Joseph W. Doherty
You need to insure you have sufficient bandwidth that your ports do not queue traffic for more than your latency allowance.  You might also look to see if your switches support cut through switching.
