Network loop
RajaHassamIrfan86583
Frequent Visitor
Frequent Visitor
I am facing an issue. My network gets unstable for a minute and port of one switch goes to error disable and reason i get is loopback. I am not able to identify the issue. i have enabled err disable loopback but it makes network unstable for some time when there is issue if i disconnect that one switch from the network. the whole network works fine there is no time out then. The loop is detected on interface which is connected to root Switch. Conf of the switch having issue is attached.
11 Replies 11
There is l2 loop'
Can you share the topolgy
MHM
Switches are connected as figure and  RSTP is used on all switches
Show spanning tree
Share output
MHM
Spanning tree pix attached
Ruben Cocheno
@RajaHassamIrfan86583
Make sure that you don't have STP disabled on any port of that switch that you disconnected. You can also disable all ports and leave only the uplinks up, and enable port by port if you are not sure what port is causing problems. Also check the logs
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
@Ruben Cocheno I have done this but this didnt solved the issue. In logs it shows loopback detected on main cable connected the root switch
I have enabled loopback recovery but it disrupts the whole network which is creating issues for all users
Ruben Cocheno
if the root cause is the main cable, then remove it if you have redundancy for that. If not check STP on the switch after that main cable/
when i remove the cable of that switch the network works smoothly but when plugged in it again start same issue and not able to odentify the problem
The topolgy you share is hub and spoke and you share multi show spanning tree
Can yoh share only the show spanning tree (and summary) of hub and switch that have issue
MHM
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 16385
Address 3c26.e43c.bf00
Cost 4
Port 1 (GigabitEthernet0/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 885a.9207.d100
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi0/1 Root FWD 4 128.1 P2p
Gi0/9 Desg FWD 19 128.9 P2p
Gi0/11 Desg FWD 19 128.11 P2p
Gi0/13 Desg FWD 19 128.13 P2p
Gi0/15 Desg FWD 19 128.15 P2p
Gi0/17 Desg FWD 19 128.17 P2p
Gi0/19 Desg FWD 4 128.19 P2p
Gi0/23 Desg FWD 19 128.23 P2p
Summary
Root bridge for: none
EtherChannel misconfig guard is enabled
Extended system ID is enabled
Portfast Default is disabled
Portfast Edge BPDU Guard Default is disabled
Portfast Edge BPDU Filter Default is disabled
Loopguard Default is enabled
PVST Simulation Default is enabled but inactive in rapid-pvst mode
Bridge Assurance is enabled
UplinkFast is disabled
BackboneFast is disabled
Configured Pathcost method used is short
Name Blocking Listening Learning Forwarding STP Active
VLAN0001 0 0 0 8 8
1 vlan 0 0 0 8 8
