Network Monitoring / Port
dannyaston
Hi all,
I have just installed two
SG200-26 26-Port Gigabit Smart Switch
The reason these have been put in is becasue randomly the network runs very slow. I was wondering if there where any tools our there that would let me check the Cisco switches for any ports sending excessive packets / drops etc.
Danny
John Blakley
Danny,
You'd need to enable snmp support in order to poll interfaces, and this switch apparently may not support it:
https://supportforums.cisco.com/thread/2158139
If you decide to go with something that does support snmp, you could use something like Solarwinds Orion or MRTG to be able to poll interfaces. I don't have experience with these switches, but you may have a web interface that you can get into to view port statistics as well.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
