Crypto using SDFlash
mpanganiban
Frequent Visitor
Frequent Visitor
I recently added an SDFlash memory to an IE2000 switch.  In event of a switch failure, I can just the SD memory card into the new one. Both IOS and configuration is working correctly and tested.  I noticed that the crypto key that was created for using SSH was not working.  I created a new one by issuing a "crypto key generate rsa"  and created 1024 bit modulus.  It's been verified and works however, after reloading the switch, it is not saving the mypublic rsa key.
The transport input is set for telnet and ssh and
paolo bevilacqua
Could  be a bug, try updating IOS.
