Network problem with WinXP and 7
captain_nl
Hi I am trying to build a network between my old Headstart Windows XP computer and my new Medion Windows 7 PC: They are connected through a Cisco Linksys E1000 router by cables (not wireless).
In my new Win7 PC I can see both computers in the Network overview (see left part of the picture below). But I cannot access the old XP computer (I did share the harddisk) nor does it appear when I lauch Windows Explorer.
What do I do wrong? I did already unable the firewall of the router, but that does not help.
Thanks in advance for any help.
Rob
darren.g
Level 5
Level 5
Rob
This is more a Windows problem than a networking problem.
Windows XP and Windows 7 use different levels of encryption by default when it comes to network communications - which makes it difficult to share drives between XP and Windows 7 machines.
Fixing this situation requires modifying the security policies on the Windows 7 machine, and should NOT be attempted unless you are confident with using the Microsoft policy and registry editors.
See this link for sugestions on resolving the issue
http://social.technet.microsoft.com/Forums/en-US/w7itpronetworking/thread/ed05788a-af43-4df6-b124-fdb57391752e/
Cheers
P.S. I'm assuming you have basic connectivity between the machines - can you PING the XP machine from your Windows 7 machine and vica-versa? If you can't, then you need to get into checking IP configurations etc on the PC's to make sure they match.
