Prompt respond from SUP COLD state
Rojer-bkk
Hi Expert,
If SUP card stay in COLD state, can i access the card via 'session slot' command or console cable?
I tested in lab, i couldn't get any prompt when i access to the card via console cable.
Reza Sharifi
You can try this
Reboot the stand-by Sup while you are connected to it via console.  If it boots correctly, login to the first sup and provide the output of "sh redu"
Hi Reza,
Thanks for reply.
I mean when sup card went to the COLD state, you cannot get any access to the card? even you try console the card?
