01-30-2015 11:13 AM - edited 03-07-2019 10:26 PM
Hello Everyone,
This is my first post and I am hoping I have come to the right place.
Background: I work for a non-profit and we are hoping to get new switches this summer. Our networking infrastructure consist of LAN and WLAN. We are currently using Cisco Catalyst 6509 for the LAN and Meraki APs for WLAN.
Problems/Symptoms:
We having experiencing different issues on different fronts. We are experiencing huge network slow downs when editing over the Network, the connections slow down almost to a halt. Also whenever users attempt to download a file large than 100mb their download halts between 50 to 70 mb. Additionally the log is showing constant flapping.
Log: has been attached.
some questions: What should I be looking for in the network connections ? Is the flapping causing the slow down ?
Any assistance/help would be greatly appreciated.
01-30-2015 01:01 PM
What is your current design looks like?
How is everything connected? Can you provide a diagram?
01-30-2015 03:12 PM
01-30-2015 03:41 PM
The flapping could well be a symptom of what is causing the slowdown.
Firstly you need to identify what devices are connected to the ports mentioned in your log.
Note you don't need to identify all the mac addresses but can you confirm what those ports connect to.
Secondly we need to know a bit more about your network ie.
1) how many vlans do you have or is everything in one vlan ?
2) what version of STP are you running on the 6500s and the Dell switches because there may be an interoperability problem between them
3) are your wireless APs autonomous because there is no sign of a controller in your diagram?
Should just say I have very little knowledge of wireless but some of the people in this forum do so they may add to it.
Is this happening all the time or is it at specific times.
Finally for the moment are most of the clients connected directly to either the 6500 or Dell switches.
If so can you post the configuration of a typical host port from the 6500 and also the configuration of the 6500 port that connects to the Dell switch.
These kind of problems can be difficult to track down so it could be a long process.
Jon
02-03-2015 07:16 AM
Hey
Sorry I was away for a bit.
1. We have 3 active vlans, however, vlan 1 the default vlan is the only one being used. The other two vlans don't have any ports attached to them.
2.
Switch is in rapid-pvst mode
Root bridge for: VLAN0001, VLAN0010, VLAN0020
EtherChannel misconfig guard is enabled
Extended system ID is disabled
Portfast Default is disabled
PortFast BPDU Guard Default is enabled
Portfast BPDU Filter Default is disabled
Loopguard Default is disabled
UplinkFast is disabled
BackboneFast is disabled
Pathcost method used is short
Name Blocking Listening Learning Forwarding STP Active
VLAN0001 0 0 0 45 45
VLAN0010 0 0 0 2 2
VLAN0020 0 0 0 2 2
3 vlans 0 0 0 49 49
2. the controller for the wireless AP is host by Meraki, so it is off prem.
I was able to isolate the problems on to the 7th floor, whenever I am connected to the LAN or APs on the 6th floor I don't experience the problems.
02-03-2015 09:22 AM
Did you manage to identify which devices were connected to the flapping links in your log ?
Also the output above shows what version of STP is running on the 6500, what about the Dell switches ?
Jon
02-03-2015 03:16 PM
So,
the port doing the flapping is connected to a network HUB that is currently connecting all the Meraki APs. Also the Dell Switch doesn't support STP.
02-03-2015 03:21 PM
How is the hub connected to the rest of the network ?
Jon
02-03-2015 03:38 PM
02-06-2015 12:30 PM
Hi Jon,
I have done a couple of things:
1. removed the hub between the APs and Cisco switch
2. read through the logs and located the mac address to it's client
The flapping is happening within on the AP ports at the switch. The devices flopping are happening to devices moving from AP to AP. I found my brand new iPhone flapping between ports. So I can eliminated virus or torrent-ing.
I can't tell what else should I be looking at to find why the switch is performing slowly.
02-06-2015 01:14 PM
Removing the hub is a good start.
When you get bad performance on the 7th floor are the source and destination IPs on the same floor ie. the communication never goes down the 6th floor ?
Have you checked all the interfaces for end clients to make sure there no collisions on the ports ?
If the server you are copying to and from when editing is on the other floor also check the ports that connect your switches together.
I am sorry for all the questions but these things take time to trace down and we need to eliminate things one by one.
Jon
02-12-2015 01:52 PM
Hey Jon
Thanks for the questions and continuous response. It is very helpful.
1. We get bad communication when the source is on the 7th floor and the destination doesn't matter.
2. How to I check for collisions exactly ?
3. the port that connects both floors is using portchanneling 1/ trunk. What exactly should I be looking for there ?
Observations:
The flapping is happening whenever a person moves from one AP to another, but it is happening too many times per second.
Should I put the APs on a different vlan to help reduce the broadcasting ? If yes, would I have to change the IP address for the AP-vlan? could I keep the IP address the same ?
Sorry for all the questions. I really appreciate the help .
Odaro
02-12-2015 05:42 PM
No problem with the questions.
So how many mac changes are you seeing every minute for example ?
This could be causing issues with the 6500 if there are too many of them but I don't know why the other floor is not experiencing those issues.
I am not a wireless person but I believe you can see mac notifications if a person does roam but if you are seeing a lot of them in a short time the obvious question I guess is why are there so many roams ?
What I would like to do is try and rule out the wireless and the mac flapping to see if you then get good performance with copying and editing but I appreciate it is not that simple to do.
Where are the servers that are used for storing the data ie. which floor ?
Jon
02-13-2015 03:39 AM
From the 6500 can you post the output of -
"sh spanning-tree vlan 1"
Jon
02-13-2015 09:24 AM
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 8196
Address 00d0.0405.0c01
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 8196
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Gi1/2 Desg FWD 4 128.2 P2p Peer(STP)
Gi4/4 Desg FWD 4 128.388 P2p
Gi4/7 Desg FWD 4 128.391 P2p
Gi4/9 Desg FWD 4 128.393 P2p
Gi4/10 Desg FWD 19 128.394 P2p Peer(STP)
Gi4/12 Desg FWD 100 128.396 P2p
Gi4/13 Desg FWD 4 128.397 P2p
Gi4/14 Desg FWD 19 128.398 P2p
Gi4/21 Desg FWD 4 128.405 P2p
Gi4/23 Desg FWD 19 128.407 P2p
Gi4/30 Desg FWD 19 128.414 P2p
Gi4/35 Desg FWD 4 128.419 P2p
Gi4/38 Desg FWD 4 128.422 P2p
Gi4/39 Desg FWD 4 128.423 P2p
Gi4/40 Desg FWD 4 128.424 P2p
Gi4/43 Desg FWD 4 128.427 P2p
Gi4/44 Desg FWD 4 128.428 P2p
Gi4/47 Desg FWD 4 128.431 P2p
Gi5/1 Desg FWD 19 128.513 P2p
Gi5/3 Desg FWD 4 128.515 P2p
Gi5/10 Desg FWD 19 128.522 P2p
Gi5/14 Desg FWD 4 128.526 P2p
Gi5/21 Desg FWD 100 128.533 P2p
Gi5/25 Desg FWD 100 128.537 P2p
Gi5/31 Desg FWD 4 128.543 P2p
Gi5/33 Desg FWD 4 128.545 P2p
Gi5/34 Desg FWD 4 128.546 P2p
Gi5/35 Desg FWD 4 128.547 P2p
Gi6/20 Desg FWD 4 128.660 P2p
Gi7/5 Desg FWD 4 128.773 P2p
Gi7/6 Desg FWD 4 128.774 P2p Peer(STP)
Gi7/16 Desg FWD 4 128.784 P2p
Gi7/31 Desg FWD 4 128.799 P2p
Gi7/38 Desg FWD 4 128.806 P2p
Gi7/39 Desg FWD 4 128.807 P2p
Gi8/11 Desg FWD 4 128.907 P2p
Gi8/12 Desg FWD 4 128.908 P2p
Gi8/22 Desg FWD 4 128.918 P2p
Gi8/24 Desg FWD 4 128.920 P2p
Gi8/35 Desg FWD 100 128.931 P2p
Po3 Desg FWD 3 128.1667 P2p
