Network Sample
Francis Jr Asis
Can anybody give me a sample configuration of a network design with a core switch (4500 or 3700X series) and any access layer switch (2960 or other) that is nework together with VLAN and any configuration. And uplink SFP either 1 GB or 10GB. Thank you.
Hi Francis,
I believe below sample will help you, pls. go through and update.
core switch (4500 or 3700X series) Configurations
Create required VLAN's on Core switch..like below
vlan 2
name Guest
vlan 102
name Admin_Vlan
vlan 104
name Wi-Fi-Vlan
vlan 105
name Spare-Vlan
interface Vlan1
no ip address
shutdown
interface Vlan2
description *** Guest Vlan ***
ip address 10.28.64.254 255.255.255.0
interface Vlan102
description *** Admin_Vlan ***
ip address 10.28.63.254 255.255.255.0
interface Vlan104
description *** Wi-Fi-Vlan ***
ip address 172.22.15.254 255.255.255.0
interface Vlan105
description *** Spare-Vlan ***
ip address 172.22.16.254 255.255.255.0
interface GigabitEthernet0/1 ( for uplinking )
description *** Connected to Access Switch ***
switchport mode trunk
Assess SW Configuration
description *** Connected to Core ***
switchport nonegotiate
spanning-tree guard loop
interface FastEthernet1/0/1
switchport access vlan 2
switchport mode access
spanning-tree portfast
interface FastEthernet1/0/2
switchport access vlan 102
interface FastEthernet1/0/3
switchport access vlan 104
interface FastEthernet1/0/4
switchport access vlan 105
nkarthikeyan
Level 7
Level 7
Hi Francis,
What is your requirement? can you brief out the requiremement. how do u want redundant core infrastructure... i.e . dual uplinks.... so that i can suggest a sample template.....
I was ask to design a network for hotel. to be use by 31 guest room @ each floor and have 7 floors, all will be 31x7 =217 guest and around 50 users for admin. i used 2960s switch each floor and a core 3750x 24SFP. This will be having maximum of 4 VLAN, VLAN1 for guest, VLAN2= admin,VLAN3 for wifi and VLAN4 for spare. I want to see sample of configuration in this kind of configuration special in 3750x series to be a layer 3.
Hi Francis,
vlan 2
name Guest
vlan 102
name Admin_Vlan
vlan 104
name Wi-Fi-Vlan
vlan 105
name Spare-Vlan
interface Vlan1
no ip address
shutdown
interface Vlan2
interface Vlan102
interface Vlan104
interface Vlan105
