%PQII_PRO_FE-1-TXERR:
m.flaviano
9 Replies 9
prymus_76
What a coincidence!  I am getting the exact same error on a brand new Cisco 891 that I just deployed.
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 29-Oct-10 00:19 by prod_rel_team
Hello. I have 3 of the 891 routers with the same error.
Sep  6 11:46:45.387: %PQII_PRO_FE-1-TXERR: GigabitEthernet0: Fatal transmit error. Restarting...
I have no sevice contact (smart net) but hardware is younger than three months.
Have the TAC solution for this problem or should I use warranty?
May be ther is a defective batch of 891 routers?
"%PQII_PRO_FE-1-TXERR: GigabitEthernet0: Fatal transmit error. Restarting"
This message means tx ring of the interface is stuck so this port could not send
traffic at that time and this port is being restarted.
++ Are we seeing any "unknown protocol drops"?. If it so then we need to check the
peer connected to the interface/tunnel.
I found a bug (CSCtb54459), but it is in verified state.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?
method=fetchBugDetails&bugId=CSCtb54459
1st Found-In
15.1T
Hope this helps
cheers
Somu
Rate helpful posts
I am seeing this on a 881 with 15.0(1)M7, connected 10Mb half duplex to cable modem.
The bug above cannot be displayed due to "not being correctly assigned to a product".
Can someone from Cisco shed some more information ?
Hi!
I my enviromen BUG is gone ater upgrade to  152-2.T1.
Thanks for the info.
Seems like hardcoding speed and duplex chased away the issue with present IOS.
hi paolo,
i have the same issue with one of our 881 with IOS 15.0(1)M5.
005943: May 18 07:38:22.427 UTC: %PQII_PRO_FE-1-TXERR: FastEthernet4: Fatal transmit error. Restarting...
FE4 is currentlyset to auto/auto. did you hardcode yours to 100/full and then the error disappeared? thanks in advance!
Hi johnlloyd_13,
Did you try the trick of fixing in 100/full? Did it resolve the problem?
I'm facing the same problem with a 881 on 12.4(22r)YB5.
Gauthier
If I remember correctly, I did hardcode FE4 to 100/full and the error log stopped.
