Network Switch Pinging Issue from Specific Server
Asad Mirza
Visitor
Dear Concern,
I have connected a Cisco Catalyst series WS-C3560G-24PS-S switch to my network. I have installed 'The Dude' server to monitor the status of the equipment, and this switch is added to the server. The Dude server stops pinging this switch after it restarts, while it continues to ping other switches with IPs on the same network. Additionally, after restarting the switch, it initially responds to pings from the Dude server for a short period, but later experiences request timeouts. Interestingly, other users on the network can successfully ping and access the switch, and all connected devices seem to be functioning correctly. How should I troubleshoot to identify whether the issue is related to SNMP or another component?
balaji.bandi
What is the Switch IP address, what is Dude IP address ?
from Switch are you able to ping DUDE IP address ?
Do you see any obnormal Logs on the Switch ?
check is the SNMP running on the switch ?
what IOS code running on the device ? (show version)
BB
Ruben Cocheno
@Asad Mirza
Can you do a traceroute before and after reboot the switch? also do you have a quick diagram L1/L2/L3? Makes it easier
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
