Network switch prompt issue for product "WS-C3850-12X48U-L"
narmali
Doing testing with "WS-C3850-12X48U-L" product. When I boot the ios image into the switch, I am getting "cisco>" prompt then after enabling it, it ask for the password. After giving password it comes to "cisco#" prompt. Now, I want to remove this password protection and want to get the "switch#" prompt. kindly, help for this.
2 Accepted Solutions
Julio E. Moisa
Please correct me if I understanding wrong the question, are you referring to the enable password?
Example
Cisco>enable
Password:
It could be removed it using:
conf t
no enable password
or
no enable secret
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
You are welcome :-)
To change the hostname of a device you can use:
conf t
hostname <new name>
example:
hostname Switch
Then you can save the configuration, executing:
Switch# write memory
Hope it is useful
5 Replies 5
Julio E. Moisa
Example
Cisco>enable
Password:
conf t
no enable password
or
no enable secret
narmali
Hi Julio Moisa,
You got my question correctly. But I also want to change my "cisco#" prompt to "switch#" prompt. Now its coming like below picture.
Thanks for your commands help.
Thanks & Regards,
Narpat Mali
You are welcome :-)
conf t
hostname <new name>
example:
hostname Switch
Hope it is useful
Thanks Julio Moisa, for your valuable response:-)
Narpat Mali
You are welcome, It was a pleasure,
Have a great day!
