Network switch SG550XG-8F8T16 port boot in Debug without software
Alain P.
I have 3 network switches, SG550XG-48T, SG550XG-24T and SG550XG-8F8T. The two first are configured and stacked together. The 3rd, SG550XG-8F8T doesn't want to boot in normal mode. I can't access it via its Web page and I can't ping its default ip address 192.168.1.254. When I connect through the Console port, I can see only a ">" character as prompt and only 2 commands are available, "debug" and "help". I don't know what's happen.
I reset to the default factory settings but the issue still remains.
I get the following error message when I was connected through the Console port :
04-Aug-2016 07:16:47 %Box-F-SLOT-NULL: Function : unit number 1 slot number 1 is NULL pointer
***** FATAL ERROR *****
Reporting Task: UTST.
Software Version: 2.2.5.68 (date Aug  4 2016 time 19:34:42)
ros(HOSTG_fatal_error+0x14) [0x250ebc]
ros(OSSYSG_fatal_error+0x148) [0x792804]
ros() [0x5c6d04]
ros(BOXG_get_port_mac_address+0x308) [0xae5544]
ros() [0x712278]
ros() [0x712564]
ros() [0x712a80]
ros() [0x713240]
ros(MSCMG_call+0x24) [0x749d0c]
ros() [0x712608]
/lib/libp2linux.so.1(+0x3aa4) [0xb6ec2aa4]
/lib/libpthread.so.0(+0x6e64) [0xb6e9de64]
***** END OF FATAL ERROR *****
^^ this event was logged before the last reboot.
04-Aug-2016 07:14:28 %SYSLOG-N-LOGGING: Logging started.
When I run a reboot, please check if the following could help to know what's happen during boot:
Resetting local unit
*****************  SYSTEM RESET  *****************
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
BootROM 1.20
Booting from NAND flash
DDR3 Training Sequence - Ver 5.3.DDR3 Training Sequence - Run with PBS.
BootROM: Image checksum verification PASSED
ROS Booton: Mar 16 2016 17:41:18
Press x to choose XMODEM...
Running UBOOT...
U-Boot 2013.01 (Aug 04 2016 - 19:35:02) Marvell version: 2014_T3.0_eng_dropv6 2.2.52
Loading system/images/active-image ...
Uncompressing Lin done, booting thln: console: File exists
Thu Aug  4 07:13:00 UTC 2016
[H[JLinux MARVELL_LINUX 3.4.69 #2 SMP Thu Aug 4 19:36:14 IDT 2016
MAC Address   :  00:8e:73:d8:a4:61.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
*** Running  SW  Ver. 2.2.5.68  Date Aug  4 2016  Time 19:34:42 ***
HW version is V01
Base Mac address is: 00:8e:73:d8:a4:61
Dram size is  : 512M bytes
Dram first block size is  : 370688K bytes
Dram first PTR is  : 0x80000000
Dram second block size is  : 4096K bytes
Dram second PTR is  : 0x19000000
Flash size is: 256M
04-Aug-2016 07:13:08 %CDB-I-LOADCONFIG: Loading running configuration.
04-Aug-2016 07:13:08 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - SG550XG-8F8T
Device 0: GT_98CX8123 (Hooper)
CPLD version is: 0x01
-- Unit Number 3                  --
04-Aug-2016 07:13:28 %INIT-I-InitCompleted: Initialization task is completed
Detected speed: 115200
If someone have an idea about this issue, it will be very nice. I'm not Cisco engineer. I just need to used this 3 switches to change the VLAN setting port from an small program trhough a Telnet connection.
Thanks for your support.
Alain Pedrotti
0 Replies 0
