Network Switches Identification
pmehanna
Dear Gents,
i received the below BOQ along with the attached drawing.
in your opinion which switches are suitable for each?
BOQ1:
POE switch 48 port   142
NPOE switch 48 port 36
L2 Failover SW 48 port 71
L3 2
BOQ2:
POE switch 48 port  20
NPOE switch 48 port 5
L2 Failover SW 48 port 10
L3 2
The same drawing applies for both BOQ.
Mark Malone
There are multiple platforms would suit that , new 9k campus would be the latest 9300-48P , 36 and 38 series would work too
I would advise though you look yourself , a helpful tool for selecting exactly what you need below
Ive narrowed it down on this link to see what campus models would work
https://www.cisco.com/c/en/us/products/switches/switch-selector.html?guide=enterprise-e|new-e|access-e|campus-e|campusge-e
Thank you Mark... appreciate your reply.
