New C9407R blades will not power on
Good day Folks,
So I am here because I am stuck. Just received a brand new C9400 series switch and my blades will not power on. When I did a show module command, it shows that the modules are recognized but show in a power-deny state. Please help.
There shouldn't be any confusion. These PSUs need 220 power input in order to power up the whole chassis.
These PSUs take c19-c20 power cords. Is that what you are using? Does the back of the power supply look like the picture?
https://www.allhdd.com/power-supply/switching-power-supply/c9400-pwr-3200ac-cisco-3200-watt-ac-power-supply-for-cisco-catalyst-9400.-new-factory-sealed./?src=ggl&gclid=Cj0KCQjwn8_mBRCLARIsAKxi0GLUJNo4XLEMxkNY6nO_jCDQ2Ww7XHAoGe1ReirL5dX0sFiaYlCBwmAaAk...
Is your power source 220?
10 Replies 10
Reza Sharifi
Do you have enough power for the system?
Can you post the output of "sh module" and "show power detail"?
Here is the information you requested.
Show Module
Mod Ports Card Type Model Serial No.
1 48 48-Port 1 Gigabit Ethernet (SFP) C9400-LC-48S JAE231505V8
2 48 48-Port UPOE 10/100/1000 (RJ-45) C9400-LC-48U JAD23140FB2
3 10 Supervisor 1 Module C9400-SUP-1 JAE2301144P
4 10 Supervisor 1 Module C9400-SUP-1 JAE23011TRX
5 48 48-Port UPOE 10/100/1000 (RJ-45) C9400-LC-48U JAD231509EL
6 48 48-Port 10/100/1000 (RJ-45) C9400-LC-48T JAE23150AV0
Mod MAC addresses Hw Fw Sw Status
1 F80F.6FEF.1384 to F80F.6FEF.13B3 1.0 16.6.2r[FC1] 16.10.01 power-deny
2 D478.9B68.30E0 to D478.9B68.310F 1.1 16.6.2r[FC1] 16.10.01 power-deny
3 D4E8.8057.5F2C to D4E8.8057.5F35 2.0 16.6.2r[FC1] 16.10.01 ok
4 D4E8.8057.5F36 to D4E8.8057.5F3F 2.0 16.6.2r[FC1] 16.10.01 ok
5 00FD.229B.0E00 to 00FD.229B.0E2F 1.1 16.6.2r[FC1] 16.10.01 power-deny
6 00EE.AB63.8DB0 to 00EE.AB63.8DDF 1.1 16.6.2r[FC1] 16.10.01 power-deny
Mod   Redundancy Role       Operating Redundancy Mode    Configured Redundancy Mode
3       Active                          sso                                         sso
4       Standby                       sso                                         sso
Show power detail
Supply Model No Type Capacity Status 1 2 3 4
PS1 C9400-PWR-3200AC ac n.a. active good good good good
PS2 C9400-PWR-3200AC ac n.a. active good good good good
PS3 C9400-PWR-3200AC ac n.a. active good good good good
PS4 C9400-PWR-3200AC ac n.a. active good good good good
PS5 C9400-PWR-3200AC ac n.a. active good good good good
PS6 C9400-PWR-3200AC ac n.a. active good good good good
PS Current Configuration Mode : Combined
PS Current Operating State : Combined (Insufficient Input Power)
Power supplies currently active : 6
Power supplies currently available : 6
Power Summary Maximum
(in Watts) Used Available
System Power 1360 0
Inline Power 0 0
Total 1360 0
System needs 1360 watts additional power.
Automatic Linecard Shutdown : Disabled
Power Budget Mode : Dual Sup
autoLC Power Out of In
Mod Model No Priority State Budget Instantaneous Peak Reset Reset
1 C9400-LC-48S 0 denied 5 0 0 170 5
2 C9400-LC-48U 1 denied 5 0 0 65 5
3 C9400-SUP-1 0 accepted 400 231 246 400 130
4 C9400-SUP-1 0 accepted 400 230 246 400 130
5 C9400-LC-48U 2 denied 5 0 0 65 5
6 C9400-LC-48T 3 denied 5 0 0 65 5
-- Fan Tray 0 accepted 540 -- -- 540 --
Total 1360
You don't have enough input.
What type of power circuit do you have?
These PSUs usually take 220s
I would like to thank you for all your help. After reviewing your comments I went ahead and ordered power cables for the new unit and the unit powered all the way thru. Thank you so much for your help.
So they need 220 volts and not 120 correct??
Correct. The input needs to be 220. 110 will not power it up. And the cable is c19-c20
Also, see page 24 in this link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/hardware/install/b_c9400_hig.pdf
I am a little confused. I have six power supplies running at the same time. The cord that was sent to me by Cisco themselves was for a 120 volt system. I just spoke to the company where I purchased my APC's and I have enough power to support the equipment, but because the power supplies does not work at full capacity unless it is under 220 volts. Is that correct. I am soo confused.
Yes it does but the power cords supplied does not mount directly to my APC. It gets attached to the transformer and the transformer is pushing 140 volts.
When you say "APC" you mean the PSU or you actually have a backup unit using APC product. Anyway, the issue is that the source is no 220.
