New Switch issues
ianbradshaw673769158
Community Member
We have just received a new Cisco IE 4010 switch, when I boot it up, I keep getting to the same point and I can not enter any commands into the CLI, all LED's on the unit look fine. it seems to stop every time once it confirms the two PSU's are good but I cannot get any further, any suggestions welcome.
CPU rev: B
Image passed digital signature verification
Board rev: 5
Testing DataBus...
Testing AddressBus...
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: dc:77:4c:c2:8a:80
The password-recovery mechanism is enabled.
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 829440
mifs[5]: Bytes available : 976896
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 1 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 133632
mifs[6]: Bytes available : 3737088
mifs[6]: mifs fsck took 0 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 1 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 1897 files, 80 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 38248448
mifs[9]: Bytes available : 83937280
mifs[9]: mifs fsck took 1 seconds.
...done Initializing Flash.
Loading "sdflash:/ie4010-universalk9-mz.152-6.E1/ie4010-universalk9-mz.152-6.E1.bin"... Verifying image sdflash:/ie4010-universalk9-mz.152-6.E1/ie4010-universalk9-mz.152-6.E1.bin.....................................................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "sdflash:/ie4010-universalk9-mz.152-6.E1/ie4010-universalk9-mz.152-6.E1.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IE4010 Software (IE4010-UNIVERSALK9-M), Version 15.2(6)E1, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 06-Mar-18 07:42 by prod_rel_team
Initializing flashfs...
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 829440
mifs[7]: Bytes available : 976896
mifs[7]: Initialization complete.
mifs[8]: 1 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 133632
mifs[8]: Bytes available : 3737088
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 1897 files, 80 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 38248448
mifs[11]: Bytes available : 83937280
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: MA BIST : End, Status Skipped
FPGA Initialization done!
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
Downloading FPGA image ...... done
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Skipped
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Skipped
Waiting for Port download...Complete
Initializing Port Extension Feature Support...
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco IE-4010-16S12P (APM86XXX) processor (revision T0) with 1048576K bytes of memory.
Processor board ID FDO2443J6L0
Last reset from power-on
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : DC:77:4C:C2:8A:80
Motherboard assembly number : 73-101623-03
Motherboard serial number : FDO24430KLX
Model revision number : T0
Motherboard revision number : D0
Model number : IE-4010-16S12P
System serial number : FDO2443J6L0
Top Assembly Part Number : 68-6048-01
Top Assembly Revision Number : P0
Version ID : V01
Hardware Board Revision Number : 0x05
Backplane FPGA version : 1.1A
CIP Serial Number : 0x22C28A80
SKU Brand Name : Cisco
Switch Ports Model SW Version SW Image
* 1 28 IE-4010-16S12P 15.2(6)E1 IE4010-UNIVERSALK9-M
SD Flash Manufacturer : SMART MODULAR (ID=89h)
Serial number : 10149169
Press RETURN to get started!
*Mar 1 00:00:08.311: Read env variable - LICENSE_BOOT_LEVEL = lanbase
*Jan 2 00:00:01.876: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ie4010 Next reboot level = lanbase and License = lanbase
Jan 14 03:22:31.170: Voltage margining not enabled
Jan 14 03:22:37.367: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Jan 14 03:22:37.937: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Jan 14 03:22:39.293: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Jan 14 03:23:02.181: %FLASH-6-DEVICE_INSERTED: Flash device inserted
Jan 14 03:23:02.481: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 1 inserted
Jan 14 03:23:02.485: File sdflash:ssh.enable not found
Jan 14 03:23:03.111: %SYS-5-RESTART: System restarted --
Jan 14 03:23:04.117: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
Jan 14 03:23:05.533: %POWER_SUPPLIES-5-PWR_OK: Power supply 1 is functioning
Jan 14 03:23:05.802: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 2 inserted
Jan 14 03:23:08.805: %POWER_SUPPLIES-5-PWR_OK: Power supply 2 is functioning
CPU rev: B
Board rev: 5
Testing DataBus...
USB Console INIT
executing...
cisco Systems, Inc.
CPU rev: B
Board rev: 5
Testing DataBus...
USB Console INIT
executing...
cisco Systems, Inc.
[email protected].
Version ID : V01
*Mar 1 00:00:08.301: Read env variable - LICENSE_BOOT_LEVEL = lanbase
*Jan 2 00:00:01.855: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ie4010 Next reboot level = lanbase and License = lanbase
Jan 14 03:32:09.191: Voltage margining not enabled
Jan 14 03:32:15.378: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Jan 14 03:32:15.947: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Jan 14 03:32:17.297: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Jan 14 03:32:40.181: %FLASH-6-DEVICE_INSERTED: Flash device inserted
Jan 14 03:32:40.481: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 1 inserted
Jan 14 03:32:40.485: File sdflash:ssh.enable not found
Jan 14 03:32:41.111: %SYS-5-RESTART: System restarted --
Jan 14 03:32:42.156: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
Jan 14 03:32:43.533: %POWER_SUPPLIES-5-PWR_OK: Power supply 1 is functioning
Jan 14 03:32:43.802: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 2 inserted
Jan 14 03:32:46.805: %POWER_SUPPLIES-5-PWR_OK: Power supply 2 is functioning
Jan 14 03:38:11.377: SMI Director is not configured, disabling SMI
Jan 14 03:38:11.377: disable_smartinstall_operation:Disabling SMI
CPU rev: B
Board rev: 5
Testing DataBus...
USB Console INIT
executing...
cisco Systems, Inc.
[email protected].
Version ID : V01
Jan 14 03:42:57.194: Voltage margining not enabled
Jan 14 03:43:03.399: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Jan 14 03:43:03.965: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Jan 14 03:43:05.321: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Jan 14 03:43:28.202: %FLASH-6-DEVICE_INSERTED: Flash device inserted
Jan 14 03:43:28.502: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 1 inserted
Jan 14 03:43:28.506: File sdflash:ssh.enable not found
Jan 14 03:43:29.132: %SYS-5-RESTART: System restarted --
Jan 14 03:43:30.156: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
Jan 14 03:43:31.554: %POWER_SUPPLIES-5-PWR_OK: Power supply 1 is functioning
Jan 14 03:43:31.823: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 2 inserted
Jan 14 03:43:34.826: %POWER_SUPPLIES-5-PWR_OK: Power supply 2 is functioning
5 Replies 5
balaji.bandi
what happends when you see below message hit Enter (key) : (make sure
BB
Mark Elsen
    - If an SD card is connected somewhere, remove it and try again.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thanks for the reply, tried that there but it did not seem to change the behaviour of the switch.
Ian.
is this new out of the box kit  ?  other option get in to ROMMON Load other IOS code and check ? is this possible ?
BB
Georg Pauwen
can you break into ROMMON (hit the BREAK key on your keyboard when the switch boots) ?
