Newbe on OSPF
mrahman0302
I am trying to configure ospf on the network. I have collapsed core design, users are connected to the 4500 switch and servers are connected to 3750 switches. 4500 switch is connected to the two 6500 switch via Layer3 and 3750 switches are connected via Layer2. I have also 10 different VLANs configured on the network. here is my configuration:
4500 Switch L3 config:
Int gig1/0/20
no switchport
ip address 10.1.1.2 255.255.255.252
no shut
ip route 0.0.0.0 0.0.0.0 gig1/0/20
6500 Switch Config:
Int gig1/0/20
no switchport
ip address 10.1.1.1 255.255.255.252
no shut
int vlan 800
Ip address 10.1.80.1 255.255.255.0
int vlan 700
ip address 10.1.70.1 255.255.255.0
int vlan 600
ip address 10.1.60.1 255.255.255.0
So if I want to configure OSPF routing protocol, what is the best way to configure OSPF on the network. Do I still need to configure static route on L3 interface between 4500 to 6500? Your expert opinion will help.
Jon Marshall
You wouldn't need the static routes if you are merely concerned with routing between the 6500's, 4500's and 3750's.
So on your 4500
router ospf 10
network 10.1.1.2 0.0.0.0 area 0
on your 6500
router ospf 10
network 10.1.1.1 0.0.0.0 area 0
network 10.1.80.0 0.0.0.255 area 0
network 10.1.70.0 0.0.0.255 area 0
network 10.1.60.0 0.0.0.255 area 0
you can then remove the default routes BUT
the above config only covers what you have shown in your post. If your 6500 or 4500 or both have additional subnets you need to include these in your OSPF configuration or you will lose connectivity to these subnets.
Also not sure why you have default-route on 6500 pointing to 4500 as well as on 4500 pointing to 6500 - this could cause routing loop.
Jon
