Nexos firmware upgrade
Manish Manwal
Hi Team,
I have a Cisco Nexus 3548-X switch currently running NX-OS version 9.2.2. I plan to upgrade the firmware in the following sequence: 9.2.2 → 9.2.4 → 9.3.13. For now, due to space constraints, I have uploaded the compact image.
Could you please confirm if I need to run any additional commands to install the compact image, or if I can use the standard commands typically used for standard images? I am following the procedure outlined in the document here:
Upgrade Nexus 3524 and 3548 NX-OS Software - Cisco
please let me know if i need to run some additional commands for compact image:  I have this file in my bootflash: n3500-compact.9.2.4.bin
THANKS
MANISH MANWAL
Mark Elsen
  - FYI : https://www.cisco.com/c/en/us/support/docs/switches/nexus-3000-series-switches/215781-nexus-3000-3100-and-3500-nx-os-compact.html#toc-hId-840099154
 M.
balaji.bandi
You can use USB to upgrade each step.
Also clear any large consumed logs from device see if you can make space.
Also read always relase notes (make sure you have configuration backup done out of the box to be safe?)
BB
