nexsus 5020 vpc domain peer-keepalive to ethernet interface
teymur azimov
hi dears.
i configuration vpc domain at nexsus 5020. i want to ask you one question.
is it possibly i configurate  vPC Domain  with ethernet interface not management interface.
for example at management interface i do this config.
On switch A:
interface mgmt0
ip address 192.168.200.13/30
On switch B:
interface mgmt
 ip address 192.168.200.14/30
On switch A:
vpc domain 1
 peer-keepalive destination 192.168.200.14 source 192.168.200.13 vrf management
On Switch B:
vpc domain 1
 peer-keepalive destination 192.168.200.13 source 192.168.200.14 vrf man
if it is possibly i can configurate at ethernet interface please write me how?
thank you very much.
11 Replies 11
Reza Sharifi
Yes, although it is recommended but you don't have to use the management interface for your peer keep alive.
You can use any other interface, but that interface needs to be in a separate vrf.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/configuration_guide_c07-543563.html
Hi Reza.
thank you to reply me.
The Cisco Nexus 5000 Series does not support creation or configuration of additional Virtual Route Forwarding (VRF) instances. Two VRF instances are created when the system boots: management and default. The management interface is in the VRF management instance, and all SVIs are in the VRF default instance.
you wrote that i configurate  seperate vrf, is separate vrf include default vrf instance?because nexsus 5020 does not support
additionla VRF.
my config like that:
On switch A:
interface ethernet1/1
On switch B:
On switch A:
vpc domain 1
 peer-keepalive destination 192.168.200.14 source 192.168.200.13 vrf default
On Switch B:
vpc domain 1
 peer-keepalive destination 192.168.200.13 source 192.168.200.14 vrf default
is this is configuration correct?
thanks
Hello Teymur,
You may use the default VRF.
All SVIs are in the VRF default instance
Both management interfaces and SVIs can be used for peer keepalive links. The management interface and VRF management instance are the defaults.
Please check the following link:
HTH,
Alex
*Please rate helpful posts
Hi Alexander. thanks. i read your link but there is configuration management interface.
is my config correct?do i need addional configuration?
Hi Teymur,
Please look at step 4 and the second example on the same page.
Step 4
peer-keepalive destination ipaddress [hold-timeout secs | interval msecs {timeout secs} | {precedence {prec-value | network | internet | critical | flash-override | flash | immediate priority | routine}} | tos {tos-value | max-reliability | max-throughput | min-delay | min-monetary-cost | normal}} |tos-byte tos-byte-value} | source ipaddress | vrf {management | default}]
Example:
Management interface for peer keepalive link:
switch(config-vpc-domain)# peer-keepalive destination 172.28.230.85
SVI for peer keepalive link:
switch(config-vpc-domain)#peer-keepalive destination 172.28.1.100 source 172.28.1.120 vrf default
Configure the IPv4 address for the remote end of the vPC peer keepalive link.
The system does not create the vPC peer link until you configure a vPC peer keepalive link.
The second example shows how to configure the SVI as the keepalive link. The source address must be specified when the VRF default instance is used for peer keepalive communication.
HTH,
Alex
ok. do i need configuration any interface for vpc peer-keepalive ?
if yes so my config like that.
On switch A:
On switch B:
On switch A:
vpc domain 1
On Switch B:
vpc domain 1
thanks.
can you say me is my configuration correct? do i need add addtional configuration for vpc keepalive?
keepaive config:
which interface i assign this ip address?(172.28.1.100-nexsus1)
can i need physical connection for keepalive link?
Its all upto you which interface you want to you as you said if its not part of management vrf then it would be part of default.
thanks Ajay.
nexsus1:
int eth 4
ip address 172.28.1.120 255.255.255.0
is it rigth?
do i need write vrf default context?
Does not make any diffrence its all upto you.
