Nexus 2248 ports for Hyper-V virtual switch uplink
JUSTIN LOUCKS
I'm having problems getting VMs sitting on a Hyper-V host to communicate properly. Does anyone know if there are issues with using the ports in on the Nexus 2248 and/or FEX modules in general for this purpose?  Since they are seen as a Virtual Switch in the Hyper-V host machine, I'm wondering if it is a limitation of the FEX module.
kitanaka
I have handy devices so tested that. I use
N2K-C2148T-1GE connected N5K-C5020P-BF-SUP NX-OS 5.0(2)N1(1)
and Win2008 server where Hyper-V is running.
I can ping from a VM to N5K SVI ip address vise versa.
Nexus & Fex Configuratin
Nexus5020-A# show run fex
!Command: show running-config fex
!Time: Tue Oct  4 07:43:35 2011
version 5.0(2)N1(1)
feature fex
fex 140
  pinning max-links 1
  description "FEX0140"
interface port-channel140
  fex associate 140
interface Ethernet1/13
  fex associate 140
Nexus5020-A# show run int e140/1/1
interface Ethernet140/1/1
  switchport access vlan 99
The VM is 99.99.99.10 / 0015.5d4e.4c05. I can ping to that from Nexus5020.
Nexus5020-A#
Nexus5020-A# ping 99.99.99.10
PING 99.99.99.10 (99.99.99.10): 56 data bytes
64 bytes from 99.99.99.10: icmp_seq=0 ttl=127 time=1.967 ms
64 bytes from 99.99.99.10: icmp_seq=1 ttl=127 time=0.857 ms
64 bytes from 99.99.99.10: icmp_seq=2 ttl=127 time=0.78 ms
64 bytes from 99.99.99.10: icmp_seq=3 ttl=127 time=0.793 ms
64 bytes from 99.99.99.10: icmp_seq=4 ttl=127 time=0.798 ms
--- 99.99.99.10 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.78/1.039/1.967 ms
Nexus5020-A# show ip arp
IP ARP Table for context default
Total number of entries: 2
Address         Age       MAC Address     Interface
99.99.99.2      00:17:15  000d.eca2.fe3c  Vlan99
99.99.99.10     00:00:22  0015.5d4e.4c05  Vlan99
Nexus5020-A# show  mac address-table vlan 99
Legend:
        * - primary entry, G - Gateway MAC, (R) - Routed MAC, O -  Overlay MAC
        age - seconds since last seen,+ - primary entry using vPC  Peer-Link
   VLAN     MAC Address      Type      age     Secure NTFY    Ports
* 99       0015.5d4e.4c05    dynamic   80         F    F  Eth140/1/1
VM (Windows 7)
Is there any configuration issue on Hyper-V side ?
Here is my VM configuration and Network Manager.
# The OS is Japanese but you can compare with yours.
Kimihito.
Thanks for the reply. I did end up figuring this out. It was a VLAN turnking issues on the core layer above the 5K and not a Nexus 2K limitation. So far the Nexus 2K switches are working out fine although I think I may be done 2960S switch stacks with the 10GB uplinks from my distribution layer if I had to do it all over again for just 10/100/1000 ports. Obviously the new 2232 models with oversubscribed 10GB ports are unique to this line of devices.
