Nexus 2248TP-E connected to Nexus 93180YC-EX
s.dina
Hi, the Fex 2248TP-E is supported on the Nexus 93180YC-EX like this table says
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/hw/interoperability/fexmatrix/fextables.html
But i need to connect them through a CVR-QSFP-SFP10G with inside a FET-10G on the Nexus93180YC-EX side
Does this type of connection work?
Thanks in advance
Stefano
FET-10giga works perfectly with adapter CVR-QSFP-SFP10G on platform Nexus 93180-YC-EX
Eth1/4 -- connected 1 full 40G QSFP-40G-SR-BD
Eth1/5 -- connected 1 full 10G Fabric Extender Transceiver
Eth1/6 -- xcvrAbsen routed auto auto --
Stefano
5 Replies 5
Reza Sharifi
FET-10G is a Cisco proprietary optic and can only be used between a FEX and a parent switch (5k, 6k, 7, 9k. etc) You can't connect 2 devices together with FET on one side and CVR-QSFP-SFP10G on the other side. Both sides have to be the same.
I would like to connecting both parts the FET-10G!!!! the only thing is that on the parent switch Nexus 93180YC-EX we've got 40giga ports so we need to reduce them fiscally from Qsfp to Sfp+ (CVR-QSFP-SFP10G)
The question is, can i use FET-10G with adapters CVR-QSFP-SFP10G on this platform, is it supported?
Nexus 2248TP-E are supported on parent switch Nexus 93180YC-EX witch split (1to4) cables.
Thank in advance
Stefano
That will not work because FET is proprietory.
Stefano
Hi Stefano,
Quick question: Does this mean the 93180YC-EX would only support a 2248TP-E fex on it's 6x QSFP28 ports with 10 G breakout?
I'm guessing from your post that FEX is not supported when attached to the 48x 1/10/25Gb ports.
James.
