05-21-2021 12:50 AM
Hi all
Wonder if someone can provide a solution to my issue.
Received a nexus 3064 that needed to re-configured to swop with another in production.
Console port produces no output at every boot with all speeds set which led me to believe a faulty console port.
Fortunately mgmt0 had an ip on as was able to login.
So I can't or couldn't do write erase reload as I would loose the mgmt0 interface and would leave me completely locked out.
So I wrote the over the startup-config with a new one with only the below config and reload:
hostname CA-PARKLAND-SW-01
interface mgmt0
vrf member management
ip address 10.222.226.1/24
I can SSH to device but not accepting the any credentials. admin / admin blank for user and password doesn't work.
Is there a way to recover or login?
Also have the usb port that I could boot from but access the switch to boot from usb.
Is there another way to boot from usb?
Appreciate any assistance.
05-21-2021 01:38 AM
since you do not have console - i go back to TAC for another RMA.
but belive device still working and you confirmed.
Try below steps :
1. Power down completly
2. wait for 5min
3. connect the console cable ( iam sure this cable working else where and good?)
4. follow beloe password recovery
no luck still go back to as suggested first place,. TAC
05-21-2021 02:40 AM
Thanks.
Yes cable is all good and will try again.
