Nexus 3172 or Catalyst 9300
fadfo
Guys,
It is a simple question but I do not know if the answer is so simple.
When should I use one instead of the other?
2 Accepted Solutions
luis_cordova
Hi @fadfo ,
The Cisco C9300 is ideal for branches, for its many features.
The Nexus 3000 are designed to be used in data centers.
Therefore, in which environment you will occupy the devices.
I leave this link with the models and their characteristics:
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9000/nb-09-cat-nexus-swtchng-sol-br-cte-en.pdf
balaji.bandi
if you have mode servers connected - Nexus 3K ( also for low lentency)
Cat 9300 is for Access or Small organisation enterprise Lan.
BB
5 Replies 5
luis_cordova
Hi @fadfo ,
Hi @luis_cordova,
It will be used to connect a proxy appliance (DMZ), so it will be placed in a Data Center.
The document that you have shared is very good and based on it I think that best option will be Nexus.
balaji.bandi
BB
Hi @balaji.bandi
You are right. For this option Nexus will be the choice.
Glad it was helpful, if help you mark as solution.
BB
