Nexus 3K Jumbo Frames
Terry MacDougal
If I enable Jumbo frames on my Nexus 3500-X, how will this effect other hosts connected to the switch that are not configured to use Jumbo Frames?
Reza Sharifi
It will not effect the hosts.
Reza Sharifi
Darian O'Dirling - TCE
Hi Terry,
There is a couple different senarios that allow for Jumbo frames. This process is done with adjusting MTU size. The following commands are for configuring MRU on a Layer 3 port
Nexus(config)#interface ethernet 1/1
Nexus(config-if)#no switchport
Nexus(config-if)#mtu 9216
This document contains all of the other senarios : https://www.cisco.com/c/en/us/support/docs/switches/nexus-9000-series-switches/118994-config-nexus-00.html
And this video provides steps for configuring MTU on a Nexus 9000 switch. The video outlines the need for proper MTU in the network and explains how to remedy MTU related interface errors, via interface MTU configuration.
https://www.youtube.com/watch?v=GbBeB6h9MKk
This video provides steps for configuring MTU on a Nexus 9000 switch. The video outlines the need for proper MTU in the network and explains how to remedy MTU related interface errors, via interface MTU configuration.
