06-01-2015 03:29 AM - edited 03-08-2019 12:17 AM
I am looking for suggestions for Nexus 3k switch recommendation. Can someone please suggest a model.
Here is my requirement:
06-01-2015 03:45 AM
I dont think the 3K's do VDC. It's meant to be a ToR switch.
06-01-2015 05:52 AM
This is correct. How about any model recommendation?
06-01-2015 06:12 AM
but you said that VDC was a requirement?
Cisco Nexus 3064-X - This 10-Gbps Enhanced Small Form-Factor Pluggable (SFP+)-based top‑of-rack switch has 48 SFP+ ports and 4 Quad SFP+ (QSFP+) ports. Each SFP+ port can operate in 100-Mbps, 1-Gbps, or 10-Gbps mode, and each QSFP+ port can operate in native 40-Gbps or 4 x 10-Gbps mode. This switch is a true phy-less switch that is optimized for low latency and low power consumption.
