What is exact effect of portfast port connected with a switch in loop ?
wfqk
Level 5
Level 5
Hi What is exact effect of portfast port connected with a switch in loop ? If a new switch is plugged into portfast port in another switch, the effect  could be the new switch will bother STP of core. Is there any effect else ? How can this cause a loop in the network ? I do not understand how to cause the loop without physical loop. Anyone can help to give me some suggestion ? Thank you
Leo Laohoo
Leo Laohoo
Go HERE.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A portfast port still runs STP, so if there's a loop, the port should block.  However, while a non-portfast port insures a loop free topology before the port is used to forward traffic, a portfast port does not.  This means a loop can be active before the portfast port blocks and it also means, a very severe loop might overload the switch before STP can block the port.
Because of the latter, portfast should be assigned with great care and something like BPDUGuard is also configured on such ports too.
