Nexus 4000 won't connect to 6509
hallvard.solem
we have a new IBM Bladechassie with two Cisco nexus 4001i switches.
I have configured one external port on each nexus and connected them to a cisco 6509 with 1G cisco SFP-modules and MM fibre.
Both the nexus and 6509 ports are configured as trunk ports, and set speed to 1000.
I see light in the SFP-modules on both devices, and through the fibre.
When I connect the devices, the link doesn't come up. No light on the ports, the nexus says "link not connected", and the 6509 says "notconnect".
I have tried reconfiguring the ports in many ways, even as accessports, nothing seems to work.
If I move the SFP and fibre from the 6509 over to a trunk port on a cisco c2960-24TC-L, the link comes up and everything is working fine.
Can anyone explain to me why this work on a 2960 and not my 6509 coreswitch?
One of the configs I've tried on the 6509:
interface GigabitEthernet2/20
description *IBM Bladechassie 2 NW1*
switchport
switchport trunk native vlan 34
switchport trunk allowed vlan 34
switchport mode trunk
end
Nexus config (works with 2960):
interface Ethernet1/15
  speed 1000
6509 ios: 12.2(33)SXI3
6509 SFP module: CEF720 24 port 1000mb SFP / WS-X6724-SFP
Thanks in advance
6 Replies 6
Reza Sharifi
On the 6509, is the SFP MM also?
If yes, try a different SFP and port
Also, make sure the patch cord's TX, and RX are not crossed.  If they are try switch the strands around and test again.
Yes, both SFP is MM, i've tried several of these.
I have also tried to cross the tx/rx cables without luck.
Yes, they are both MM. I've tried several different SFP-modules.
I have also tried to cross the fibre cables, with no luck
Does the module come up at all.  What is the output of "sh mod"?
are you using sup-720?
Yes, the module comes up, we are using sup-720.
I have a lot of other switches connected to the module, and I've also tested this port against another switch and it works fine.
sh mod:
XX#sh mod
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     XX
  2   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       XX
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-BASE     XX
  6   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     XX
  7   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     XX
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0015.62e1.2e94 to 0015.62e1.2ec3   2.3   12.2(14r)S5  12.2(33)SXI3 Ok
  2  0015.6301.7be8 to 0015.6301.7bff   2.3   12.2(14r)S5  12.2(33)SXI3 Ok
  5  0013.c42e.e8d4 to 0013.c42e.e8d7   3.3   8.1(3)       12.2(33)SXI3 Ok
  6  0024.c463.3a38 to 0024.c463.3a67   3.2   12.2(18r)S1  12.2(33)SXI3 Ok
  7  0005.7442.8d0c to 0005.7442.8d3b  10.2   7.2(1)       12.2(33)SXI3 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       XX  2.0    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       XX  2.0    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3A       XX  2.5    Ok
  5  MSFC3 Daughterboard         WS-SUP720          XX  2.5    Ok
  6  Centralized Forwarding Card WS-F6700-CFC       XX  4.1    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  5  Pass
  6  Pass
  7  Pass
Solution: the port on 6509 had to have the following configuration:
bandwidth 1000
speed nonegotiate
