08-25-2011 03:05 PM - edited 03-07-2019 01:53 AM
Do you know if it´s possible mix the topologys dual-homed with single-homed?
For example:
Two N5k, connected to 6 N2k with dual-homed and connected to 2 N2k with single-homed.
Thanks in advance,
Solved! Go to Solution.
08-25-2011 04:43 PM
Do you mean something like this?
If yes, then the answer is YES. I have a customer doing this right now. Just be aware of the hardware port-channel limit on your N5K if you are using N50x0.
jerry
08-25-2011 04:43 PM
jerry
08-26-2011 05:53 AM
Hi Jerry,
Yes, that is exactly what we want to do.
we already have some N2k as singled-homed and we want to connect one server in two different nexus, then we need dual-homed topology
Thanks a lot.
