Nexus 5000 and Fabric interconnect
Does anybody know how to properly power down the Nexus 5000 and the fabric interconnect switches? I have looked up and down cisco's and google web for steps, but they are all comming back with the answer to just disconnect the power cables after you have power down all the windows os and exs servers. Before i do that, I just wanted to make sure that that's the correct way to do it or if there are actuall commands that I will need to run on the devices to properly power down. I know that the FI do have a command to reboot, but i need them to completely be power down. Any help would be appreciated.
Reza Sharifi
Correct, 5Ks and 2ks don't have a switch that you can turn off.  So, you just have to unplug the power cord.  Make sure to save your configs before doing that.
Reza Sharifi
Cool. Thank you.
Thanks for the rating.
