Nexus 5010 vPC load-balance question
situwayne
please see attachment for reference.  my question is regarding vPC port-channel.
Can Server1 or Server2 use both uplinks simultaneously to archive theoretical speed of aggregated 20Gb/sec?  I thought this would be the case.  But I have heard of this topology is it limited to 1 active link which only 10Gb.
vvasisth
Both links should be active and the traffic will be load balanced accordingly. The concept of VPC is , from the servers point of view both nexus is 1 switch and the port channel is formed based on that concept. You will get a bandwidth of 20GB.
This will work like a charm
Do rate this post if you found it helpful.
Varun
