Nexus 5500 Multicast Routing (PIM SSM)
bmesich
First time setting up multicast routing and I'm having some trouble getting multicast traffic to route between VLANs.  I'm trying to use PIM SSM on a Nexus 5500 platform running 7.3(8)N1(1).  Use case is a Grandstream VOIP PBX (UCM6304) sending a multicast page to a VOIP phone/intercom. Below is a diagram of my setup:
Lots of confusion on my part when reading through documentation regarding limitations in vPC domains.  Below is a screenshot of my PIM configuration thus far:
 Here is a screenshot of my interface configurations.  Note that I enabled igmp version 3 on the SVI's and L3 interfaces since that seemed to be recommended.
 Next screenshot shows the PIM neighbors, but a "show ip mroute 232.0.1.100" does not indicate any Outgoing interfaces for the SSM network segment.  I assume this is a problem and is why I'm not seeing multicast traffic outside the originating VLAN.
 Last set of screenshots show the pim interfaces:
 Any help would be greatly appreciated.  The Nexus docs I found here would seem to suggest no further configuration is required for PIM SSM- which makes me think I might be in an unsupported configuration (possibly the vPC domain?).
9 Replies 9
Mark Elsen
                   - Verify these items : show ip mroute , look for outgoing interfaces and or presence of vlans
  • Ensure that the multicast source and receiver addresses belong to the same SSM range (232.0.1.0/24 in your case)
  • Verify that the multicast source is sending traffic to the correct multicast address (232.0.1.100)
  • Confirm that the multicast receivers have joined the correct multicast group (232.0.1.100)
  • Make sure that the VLANs are correctly trunked between the switches and the VLAN tags are preserved end-to-end.
  • Check if IGMP snooping is enabled on the switches and if necessary, configure the IGMP querier to avoid multicast black holes.
                Also check : "show ip pim interface", "show ip pim rpf" and "show ip pim join".
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
See below for the output of show up mroute. I don't see any interfaces listed in the outgoing interface list, which I think is part of the problem.  I have not idea how to make the SVI populate under the SSM range (232.0.0.0/8).  I can confirm the sender and receiver are on the same SSM range (232.0.0.0/8).  I can also confirm multicast listeners within the same vlan (VLAN10 in this case) are able to receive multicast traffic.  Listeners in VLAN 40 can not.
5k-1# show ip mroute
IP Multicast Routing Table for VRF "default"
(*, 224.0.1.60/32), uptime: 2d13h, igmp ip pim
Incoming interface: Null, RPF nbr: 0.0.0.0
Outgoing interface list: (count: 1)
Vlan40, uptime: 2d13h, igmp
(*, 224.0.1.75/32), uptime: 2d13h, igmp ip pim
Vlan10, uptime: 2d13h, igmp
(*, 224.0.1.116/32), uptime: 2d13h, ip pim igmp
Outgoing interface list: (count: 2)
Vlan10, uptime: 2d00h, igmp
Vlan40, uptime: 2d12h, igmp
(*, 224.0.1.187/32), uptime: 01:14:19, ip pim igmp
Vlan40, uptime: 00:48:08, igmp
(*, 232.0.0.0/8), uptime: 2d13h, pim ip
Outgoing interface list: (count: 0)
(*, 233.89.188.1/32), uptime: 2d13h, igmp ip pim
(192.168.10.116/32, 233.89.188.1/32), uptime: 2d13h, ip pim mrib
Incoming interface: Vlan10, RPF nbr: 192.168.10.116
Vlan10, uptime: 2d13h, mrib, (RPF)
(*, 239.255.255.250/32), uptime: 2d13h, igmp ip pim
Vlan40, uptime: 2d01h, igmp
(192.168.10.116/32, 239.255.255.250/32), uptime: 2d13h, ip mrib pim
Vlan40, uptime: 2d01h, mrib
(192.168.40.36/32, 239.255.255.250/32), uptime: 00:19:12, ip mrib pim
Incoming interface: Vlan40, RPF nbr: 192.168.40.36
Vlan40, uptime: 00:19:12, mrib, (RPF)
Vlan10, uptime: 00:19:12, mrib
(192.168.40.38/32, 239.255.255.250/32), uptime: 2d13h, ip mrib pim
Incoming interface: Vlan40, RPF nbr: 192.168.40.38
Vlan40, uptime: 2d01h, mrib, (RPF)
(192.168.40.39/32, 239.255.255.250/32), uptime: 00:36:03, ip mrib pim
Incoming interface: Vlan40, RPF nbr: 192.168.40.39
Vlan40, uptime: 00:36:03, mrib, (RPF)
Vlan10, uptime: 00:36:03, mrib
(192.168.40.101/32, 239.255.255.250/32), uptime: 2d13h, ip mrib pim
Incoming interface: Vlan40, RPF nbr: 192.168.40.101
5k-2# show ip mroute
(*, 224.0.1.60/32), uptime: 2d12h, igmp ip pim
(*, 224.0.1.116/32), uptime: 2d12h, igmp ip pim
(*, 224.0.1.187/32), uptime: 01:14:36, pim ip igmp
Vlan40, uptime: 00:48:25, igmp
5k-1# show ip pim interface
PIM Interface Status for VRF "default"
Vlan10, Interface status: protocol-up/link-up/admin-up
IP address: 192.168.10.2, IP subnet: 192.168.10.0/24
PIM DR: 192.168.10.3, DR's priority: 1
PIM neighbor count: 1
PIM hello interval: 30 secs, next hello sent in: 00:00:15
PIM neighbor holdtime: 105 secs
PIM configured DR priority: 1
PIM configured DR delay: 3 secs
PIM border interface: no
PIM GenID sent in Hellos: 0x116be5bd
PIM Hello MD5-AH Authentication: disabled
PIM Neighbor policy: none configured
PIM Join-Prune inbound policy: none configured
PIM Join-Prune outbound policy: none configured
PIM Join-Prune interval: 1 minutes
PIM Join-Prune next sending: 1 minutes
PIM BFD enabled: no
PIM passive interface: no
PIM VPC SVI: yes
PIM Auto Enabled: no
PIM vPC-peer neighbor: 192.168.10.3
PIM Interface Statistics, last reset: never
General (sent/received):
Hellos: 5377/5378 (early: 0), JPs: 14/0, Asserts: 0/0
Grafts: 0/0, Graft-Acks: 0/0
DF-Offers: 0/0, DF-Winners: 0/0, DF-Backoffs: 0/0, DF-Passes: 0/0
Errors:
Checksum errors: 0, Invalid packet types/DF subtypes: 0/0
Authentication failed: 0
Packet length errors: 0, Bad version packets: 0, Packets from self: 0
Packets from non-neighbors: 0
Packets received on passiveinterface: 0
JPs received on RPF-interface: 0
(*,G) Joins received with no/wrong RP: 0/0
(*,G)/(S,G) JPs received for SSM/Bidir groups: 0/0
JPs filtered by inbound policy: 0
JPs filtered by outbound policy: 0
Vlan40, Interface status: protocol-up/link-up/admin-up
IP address: 192.168.40.2, IP subnet: 192.168.40.0/24
PIM DR: 192.168.40.3, DR's priority: 1
PIM hello interval: 30 secs, next hello sent in: 00:00:04
PIM GenID sent in Hellos: 0x1199052f
PIM BFD enabled: no
PIM VPC SVI: yes
PIM vPC-peer neighbor: 192.168.40.3
Hellos: 5377/5374 (early: 0), JPs: 3/0, Asserts: 0/0
Errors:
port-channel2, Interface status: protocol-up/link-up/admin-up
IP address: 192.168.0.33, IP subnet: 192.168.0.32/30
PIM DR: 192.168.0.34, DR's priority: 1
PIM hello interval: 30 secs, next hello sent in: 00:00:05
PIM GenID sent in Hellos: 0x113f2073
PIM BFD enabled: no
PIM VPC SVI: no
Hellos: 5374/5377 (early: 0), JPs: 0/0, Asserts: 0/0
Errors:
5k-2# show ip pim interface
IP address: 192.168.10.3, IP subnet: 192.168.10.0/24
PIM hello interval: 30 secs, next hello sent in: 00:00:13
PIM GenID sent in Hellos: 0x31e30a19
PIM BFD enabled: no
PIM VPC SVI: yes
PIM vPC-peer neighbor: 192.168.10.2
Hellos: 5375/5373 (early: 0), JPs: 0/14, Asserts: 0/0
Errors:
IP address: 192.168.40.3, IP subnet: 192.168.40.0/24
PIM hello interval: 30 secs, next hello sent in: 00:00:25
PIM GenID sent in Hellos: 0x3209189c
PIM BFD enabled: no
PIM VPC SVI: yes
PIM vPC-peer neighbor: 192.168.40.2
Hellos: 5372/5374 (early: 0), JPs: 0/3, Asserts: 0/0
Errors:
IP address: 192.168.0.34, IP subnet: 192.168.0.32/30
PIM hello interval: 30 secs, next hello sent in: 00:00:24
PIM GenID sent in Hellos: 0x31b35c9e
PIM BFD enabled: no
PIM VPC SVI: no
Hellos: 5375/5371 (early: 0), JPs: 0/0, Asserts: 0/0
Errors:
5k-1# show ip pim rp
PIM RP Status Information for VRF "default"
BSR disabled
Auto-RP disabled
BSR RP Candidate policy: None
BSR RP policy: None
Auto-RP Announce policy: None
Auto-RP Discovery policy: None
5k-2# show ip pim rp
BSR disabled
Auto-RP disabled
BSR RP policy: None
5k-1(config)# show ip pim fabric info
Fabric Multicast Forwarding is DISABLED
5k-2(config)# show ip pim fabric info
Hello
Have you tried ASM instead of SSM?
Both nexus
no ip pim ssm range 232.0.0.0/8
ip pim rp-address <loopback 0> group-list x.x.x.x
Kind Regards
Paul
Hi Paul,
I have a ASM anycast-rp setup now but I'm still running into issues.  See my reply below for more info on the setup.
Thanks - Bryan
balaji.bandi
is the both VLAN not working or any one of the vlan working as expected : (some how not able to read as expected the images, if you can post all in text file will be easy to review)
what nexus OS running :
refer new 7.x code config guide :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/multicast/7x/cisco_5500_layer3_multicast_config_gd_rel_7x.pdf
BB
I don't have any VLAN's that can route multicast traffic between them. Multicast does work within the same VLAN.  For example, a multicast listener in VLAN10 can receive multicast traffic from a sender that is also in VLAN10.  Nexus version is 7.3(8)N1(1) and I copied the cmd output into tables below for easier reading.  Switch 5k-1 is on the left, 5k-2 is on the right.
5k-1# show running-config pim
!Command: show running-config pim
!Time: Sun Feb 5 09:53:11 2023
version 7.3(8)N1(1)
feature pim
ip pim log-neighbor-changes
interface Vlan10
ip pim sparse-mode
interface Vlan40
ip pim sparse-mode
interface port-channel2
ip pim sparse-mode
5k-2# show running-config pim
!Time: Sun Feb 5 09:54:21 2023
version 7.3(8)N1(1)
feature pim
interface Vlan10
ip pim sparse-mode
interface Vlan40
ip pim sparse-mode
ip pim sparse-mode
5k-1# show running-config interface vlan 10
!Command: show running-config interface Vlan10
!Time: Sun Feb 5 09:55:38 2023
version 7.3(8)N1(1)
interface Vlan10
description VLAN10 SVI
no shutdown
no ip redirects
ip address 192.168.10.2/24
no ipv6 redirects
ip ospf passive-interface
ip router ospf 1 area 0.0.0.0
ip pim sparse-mode
ip igmp version 3
hsrp version 2
hsrp 10
preempt
timers 1 4
ip 192.168.10.1
ip dhcp relay address 192.168.10.100
5k-1# show running-config interface vlan 40
!Command: show running-config interface Vlan40
!Time: Sun Feb 5 09:55:40 2023
version 7.3(8)N1(1)
interface Vlan40
description VLAN40 SVI
no shutdown
no ip redirects
ip address 192.168.40.2/24
no ipv6 redirects
ip pim sparse-mode
ip igmp version 3
hsrp version 2
hsrp 40
preempt
timers 1 4
ip 192.168.40.1
5k-1# show running-config interface port-channel 2
!Command: show running-config interface port-channel2
!Time: Sun Feb 5 09:55:46 2023
version 7.3(8)N1(1)
description L3 Transit -> Nexus 5k-sw02
no switchport
speed 10000
ip address 192.168.0.33/30
ip ospf dead-interval 40
ip ospf hello-interval 1
ip ospf network broadcast
ip pim sparse-mode
ip igmp version 3
5k-2# show running-config interface vlan 10
!Time: Sun Feb 5 09:57:11 2023
version 7.3(8)N1(1)
interface Vlan10
no shutdown
no ip redirects
ip address 192.168.10.3/24
no ipv6 redirects
ip pim sparse-mode
ip igmp version 3
hsrp version 2
hsrp 10
preempt
priority 200
timers 1 4
ip 192.168.10.1
5k-2# show running-config interface vlan 40
!Time: Sun Feb 5 09:57:13 2023
version 7.3(8)N1(1)
interface Vlan40
no shutdown
no ip redirects
ip address 192.168.40.3/24
no ipv6 redirects
ip pim sparse-mode
ip igmp version 3
hsrp version 2
hsrp 40
preempt
priority 200
timers 1 4
ip 192.168.40.1
5k-2# show running-config interface port-channel 2
!Time: Sun Feb 5 09:57:18 2023
version 7.3(8)N1(1)
description L3 Transit -> Nexus 5k-sw01
no switchport
speed 10000
ip address 192.168.0.34/30
ip pim sparse-mode
ip igmp version 3
5k-1# show ip pim neighbor
PIM Neighbor Status for VRF "default"
Neighbor Interface Uptime Expires DR Bidir- BFD
Priority Capable State
192.168.10.3 Vlan10 1d18h 00:01:33 1 yes n/a
192.168.40.3 Vlan40 1d18h 00:01:24 1 yes n/a
192.168.0.34 port-channel2 1d18h 00:01:29 1 yes n/a
(*, 224.0.1.75/32), uptime: 2d12h, igmp ip pim
Vlan10, uptime: 2d12h, igmp
(*, 224.0.1.116/32), uptime: 2d12h, ip pim igmp
(*, 224.0.1.187/32), uptime: 01:04:20, ip pim igmp
Vlan40, uptime: 00:38:09, igmp
(*, 232.0.0.0/8), uptime: 2d12h, pim ip
(*, 233.89.188.1/32), uptime: 2d12h, igmp ip pim
(192.168.10.116/32, 233.89.188.1/32), uptime: 2d12h, ip pim mrib
Vlan10, uptime: 2d12h, mrib, (RPF)
(*, 239.255.255.250/32), uptime: 2d12h, igmp ip pim
(192.168.10.116/32, 239.255.255.250/32), uptime: 2d12h, ip mrib pim
(192.168.40.36/32, 239.255.255.250/32), uptime: 00:09:13, ip mrib pim
Vlan40, uptime: 00:09:13, mrib, (RPF)
Vlan10, uptime: 00:09:13, mrib
(192.168.40.38/32, 239.255.255.250/32), uptime: 2d12h, ip mrib pim
(192.168.40.39/32, 239.255.255.250/32), uptime: 00:26:04, ip mrib pim
Vlan40, uptime: 00:26:04, mrib, (RPF)
Vlan10, uptime: 00:26:04, mrib
(192.168.40.101/32, 239.255.255.250/32), uptime: 2d12h, ip mrib pim
5k-2# show ip pim neighbor
192.168.10.2 Vlan10 1d18h 00:01:35 1 yes n/a
192.168.40.2 Vlan40 1d18h 00:01:32 1 yes n/a
192.168.0.33 port-channel2 1d18h 00:01:30 1 yes n/a
5k-2#
(*, 224.0.1.187/32), uptime: 01:03:30, pim ip igmp
Vlan40, uptime: 00:37:19, igmp
PIM hello interval: 30 secs, next hello sent in: 00:00:28
PIM BFD enabled: no
PIM VPC SVI: yes
Hellos: 5348/5348 (early: 0), JPs: 14/0, Asserts: 0/0
Errors:
PIM hello interval: 30 secs, next hello sent in: 0.009527
PIM BFD enabled: no
PIM VPC SVI: yes
Hellos: 5347/5345 (early: 0), JPs: 3/0, Asserts: 0/0
Errors:
PIM hello interval: 30 secs, next hello sent in: 00:00:14
PIM BFD enabled: no
PIM VPC SVI: no
Hellos: 5345/5347 (early: 0), JPs: 0/0, Asserts: 0/0
Errors:
PIM hello interval: 30 secs, next hello sent in: 00:00:11
PIM BFD enabled: no
PIM VPC SVI: yes
Hellos: 5348/5346 (early: 0), JPs: 0/14, Asserts: 0/0
Errors:
PIM hello interval: 30 secs, next hello sent in: 00:00:27
PIM BFD enabled: no
PIM VPC SVI: yes
Hellos: 5345/5346 (early: 0), JPs: 0/3, Asserts: 0/0
Errors:
PIM BFD enabled: no
PIM VPC SVI: no
Hellos: 5347/5344 (early: 0), JPs: 0/0, Asserts: 0/0
Errors:
Christopher Hart
Hello!
It's not completely clear where the Grandstream VOIP PBX is connected in your topology, but it may be worth configuring the vpc bind-vrf default vlan {vlan-id} command to see if that alleviates the issue. I recommend reviewing the Important Notes and Caveats section of the Create Topologies for Routing over Virtual Port Channel document for more information about this command and its usage, alongside the Binding a VRF Instance to a vPC section of the Cisco Nexus 5500 Series NX-OS Interfaces Configuration Guide, Release 7.x document.
Note that the VLAN bound to the default VRF (as well as any other non-default VRF) through this command must be a unique VLAN used solely for this purpose. I would not advise using an existing VLAN that carries production traffic.
I hope this helps - thank you!
-Christopher
Hi Christopher,
Thanks for the pointer - I'll read through the docs and try what you suggest.  I setup a L3 link between the Nexus 5k's and set ip pim sparse-mode on both ends thinking that would be needed for pim/multicast traffic between the switches.  Early documentation (Nexus version 5.x) seemed to suggest this was needed.  As for where the Grandstream PBX is, it is hanging off the 2248TP FEX on an access port in VLAN10 (indicated by the phone on the left in the diagram.)  The receiver of the multicast traffic is a phone/intercom listening in VLAN 40 (access port on the same FEX).
Thanks again - Bryan
bmesich
I've given up on PIM SSM for the time being and am now trying PIM ASM with anycast-rp.  Below is my updated configuration:
5k-1(config)# show running-config interface loopback 0
!Command: show running-config interface loopback0
!Time: Tue Feb 7 22:38:18 2023
version 7.3(8)N1(1)
interface loopback0
ip address 192.168.0.28/32
ip pim sparse-mode
ip igmp version 3
5k-1(config)# show running-config interface loopback 1
!Command: show running-config interface loopback1
!Time: Tue Feb 7 22:38:21 2023
version 7.3(8)N1(1)
interface loopback1
ip address 192.168.0.29/32
ip pim sparse-mode
ip igmp version 3
5k-1(config)# show running-config pim
!Time: Tue Feb 7 22:39:23 2023
version 7.3(8)N1(1)
feature pim
ip pim rp-address 192.168.0.28 group-list 224.0.0.0/4
ip pim anycast-rp 192.168.0.28 192.168.0.29
ip pim anycast-rp 192.168.0.28 192.168.0.30
interface loopback0
ip pim sparse-mode
interface loopback1
ip pim sparse-mode
interface Vlan10
ip pim sparse-mode
interface Vlan40
ip pim sparse-mode
ip pim sparse-mode
5k-1(config)# show ip pim rp
BSR disabled
Auto-RP disabled
BSR RP policy: None
Anycast-RP 192.168.0.28 members:
192.168.0.29* 192.168.0.30
RP: 192.168.0.28*, (0),
uptime: 1d04h priority: 0,
RP-source: (local),
group ranges:
224.0.0.0/4
5k-1(config)# show ip igmp groups 224.0.100.117
IGMP Connected Group Membership for VRF "default" - matching Group "224.0.100.117"
Type: S - Static, D - Dynamic, L - Local, T - SSM Translated
Group Address Type Interface Uptime Expires Last Reporter
224.0.100.117 D Vlan40 1d02h 00:04:19 192.168.40.34
224.0.100.117 D Vlan10 1d02h 00:04:11 192.168.10.21
5k-2# show running-config interface loopback 0
!Time: Tue Feb 7 22:38:57 2023
version 7.3(8)N1(1)
interface loopback0
ip pim sparse-mode
ip igmp version 3
5k-2# show running-config interface loopback 1
!Time: Tue Feb 7 22:38:58 2023
version 7.3(8)N1(1)
interface loopback1
ip address 192.168.0.30/32
ip pim sparse-mode
ip igmp version 3
!Time: Tue Feb 7 22:39:46 2023
version 7.3(8)N1(1)
feature pim
interface loopback0
ip pim sparse-mode
interface loopback1
ip pim sparse-mode
interface Vlan10
ip pim sparse-mode
interface Vlan40
ip pim sparse-mode
ip pim sparse-mode
BSR disabled
Auto-RP disabled
BSR RP policy: None
192.168.0.29 192.168.0.30*
RP-source: (local),
group ranges:
224.0.0.0/4
5k-2# show ip igmp groups 224.0.100.117
224.0.100.117 D Vlan40 1d02h 00:04:02 192.168.40.59
224.0.100.117 D Vlan10 1d02h 00:04:09 192.168.10.20
When I start a multicast page, I see the following change in the mroute table:
BEFORE MULTICAST TRAFFIC
5k-1(config)# show ip mroute 224.0.100.117
(*, 224.0.100.117/32), uptime: 1d02h, igmp ip pim
Incoming interface: loopback0, RPF nbr: 192.168.0.28
Vlan10, uptime: 1d02h, igmp
Vlan40, uptime: 1d02h, igmp
AFTER MULTICAST TRAFFIC STARTS
(192.168.10.120/32, 224.0.100.117/32), uptime: 00:00:09, ip mrib pim
Incoming interface: Vlan10, RPF nbr: 192.168.10.120
Vlan10, uptime: 00:00:09, mrib, (RPF)
Vlan40, uptime: 00:00:09, mrib
5k-2# show ip mroute 224.0.100.117
(*, 224.0.100.117/32), uptime: 1d02h, igmp pim ip
I see that I get a S,G entry in the mroute table with the source coming from VLAN 10 (the GrandStream PBX's IP is 192.168.10.120).  Outgoing interfaces are VLAN10 and VLAN40 - but I would expect it to also use my L3 link port-channel 2 to send to the other RP on 5k-2.  So no traffic is flowing over to 5k-2 and I don't understand why.  Also note that I have (4) listening devices show in the mroute table.  All are Grandstream GSC3516 intercoms that are configured to listen for multicast traffic on 224.0.100.117.  (2) are in VLAN10 and (2) are in VLAN40.  The VLAN10 devices will always work since they are in the same broadcast domain (VLAN) as the PBX.  The devices in VLAN 40 never receive the multicast traffic.
