Bookmark
Subscribe
1885
error when try to make un uplink between IE 2000 and Catalyst 3560
nirbb
When I try to create an uplink between the above two switches through an SFP port, I get the following error on the IE 2000 switch
Where is the problem and what is not set correctly in the switches?
15 Replies 15
marce1000
 - Learn  here what UDLD is : https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie2000/software/release/15_0_2_eb/configuration/guide/scg-ie2000/swudld.html , toggle some settings , for instance disabling but understand what you are doing ,
 M.
Hello
Can you confirm how you have created those links, as unless that switch is running in a VSS ( single control plane) you will require two separate physical links in their own trunk or access mode connecting to those two switches
Kind Regards
Paul
Leo Laohoo
The error message is due to UDLD.  That is a Layer 1 issue.
nirbb
hi all
thanks for the rapidly answers, the configuration of the SFP ports as shown  the photo.
UDLD can detect Uni-direction <<- this is cause
show udld eth x/x
so please share the output of above here
share
show udld
please
Post the complete output to the command "sh interface F1/9".
hi Leo
Thanks for your response.
Tomorrow I will be on the site taking the status of Port 1/9.
Hi Leo,
this is the complete output for FastEthernet1/9
FastEthernet1/9 is down, line protocol is down (err-disabled)
Hardware is Fast Ethernet, address is b0aa.77b2.c889 (bia b0aa.77b2.c889)
Description: Connected to Sec-sw7 interface gi1/1
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Auto-duplex, Auto-speed, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported
Last input 6d00h, output 6d00h, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
11 packets input, 1283 bytes, 0 no buffer
Received 11 broadcasts (11 multicasts)
0 watchdog, 11 multicast, 0 pause input
11 packets output, 1817 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Ok, on the 3560 switch, post the output to the command "sh interface Gi1/1" and "sh interface Gi1/2".
GigabitEthernet1/1/1
GigabitEthernet1/1/1 REP enabled
Segment-id: 100 (Segment)
PortID: 001970DB9818A980
Preferred flag: No
Operational Link Status: INIT_DOWN
Current Key: 001970DB9818A980EF1C
Port Role: Fail
Blocked VLAN: 1-4094
Admin-vlan: 100
Preempt Delay Timer: disabled
LSL Ageout Timer: 5000 ms
LSL Ageout Retries: 5
Configured Load-balancing Block Port: none
Configured Load-balancing Block VLAN: none
STCN Propagate to: none
LSL PDU rx: 0, tx: 611982
HFL PDU rx: 0, tx: 0
BPA TLV rx: 0, tx: 0
BPA (STCN, LSL) TLV rx: 0, tx: 0
BPA (STCN, HFL) TLV rx: 0, tx: 0
EPA-ELECTION TLV rx: 0, tx: 0
EPA-COMMAND TLV rx: 0, tx: 0
EPA-INFO TLV rx: 0, tx: 0
GigabitEthernet1/1/2
Security-SW7#show interfaces gigabitEthernet 1/1/2 rep detail
GigabitEthernet1/1/2 REP enabled
PortID: 001A70DB9818A980
Preferred flag: No
Current Key: 00000000000000000000
Port Role: Fail
Admin-vlan: 100
LSL PDU rx: 0, tx: 612101
Post the output to the command "sh interface Gi1/1" and "sh interface Gi1/2" from the 3560.
Please look above, I put it.
That is not the output I requested.
