Nexus 5548 and Layer 3 Routing
jecker
I have a pair of 5548's that I purchased with the layer 3 routing module as part of a bundle.  I am trying to setup some layer 3 routing between a couple of SSVI's but have not had any luck.  From one VLAN I can ping both VLAN interfaces but I can not ping across to another host.  The remote host has the same issue.  I've enabled feature intervace vlan, is something else I need to do?
I can see the layer 3 doughter card if I do a show module, but when I do a show license I don't see anything about layer 3.
Is there something else I need to do with the license or another command I need to enable layer 3 routing?  I have the layer 3 license that came with the bundle but there is no PAK or anything to register.
Thanks.
6 Replies 6
Jon Marshall
Can you do a basic check to see if the host is running a firewall that is blocking incoming ICMP. If you can ping both vlan interfaces from a host then it looks like routing is working.
Jon
Jerry Ye
Please post the output of show license usage and show feature.
jerry
We checked the hosts and everything seems fine, and we could ping those hosts when they were on the same VLAN.
Here is the output, does this look correct for layer 3 routing to work?
Thanks.
sh licee# sh licens usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FCOE_NPV_PKG                  No    -   Unused             -
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                No    -   Unused             -
FC_FEATURES_PKG               No    -   Unused             -
LAN_BASE_SERVICES_PKG         Yes   -   In use Never       -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   Unused Never       -
Dallas1-5548# sh feature | grep enable
adapter-fex           1         enabled
fex                   1         enabled
interface-vlan        1         enabled
lacp                  1         enabled
lldp                  1         enabled
sshServer             1         enabled
udld                  1         enabled
vpc                   1         enabled
vtp                   1         enabled
Dallas1-5548# sh lice
License hostid: VDH=SSI152600WS
Dallas1-5548# sh module
Mod Ports  Module-Type                      Model                  Status
1    32     O2 32X10GE/Modular Universal Pla N5K-C5548UP-SUP        active *
3    0      O2 Daughter Card with L3 ASIC    N55-D160L3             ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    5.0(3)N2(1)     1.0     --
3    5.0(3)N2(1)     1.0     --
Mod  MAC-Address(es)                         Serial-Num
1    547f.ee0d.a0c8 to 547f.ee0d.a0e7         JAF1529AFDG
3    0000.0000.0000 to 0000.0000.000f         JAF1519BJGJ
Dallas1-5548#
Yes, you have the proper license for L3.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/licensing/guide/Cisco_NX-OS_Licensing_Guide_chapter1.html#con_24753
Next question will be what kind of routing are you trying to do? Static or dynamic routing? You can configure static just like IOS, but for dynamic routing, you need to enable the feature first.
HTH,
jerry
Thanks for the help.
We are just doing static routing right now and trying to route between directly connected SVI's.  If there is no license restriction perhaps I should take a closer look at the hosts.
Hello Expert,
How we can enable the Feature for Dynamic routing?
Jehan
