Nexus 5548 connected to a WS-C3750-24FS-S
George Deanda
we are having trouble with the VPC, and etherchannel ? looked at many forums not to clear on wich one to use, this is are config, we have been getting alot of loops and kills are entire network, please help
nexus switch config,
this is on both nexus we have 2 of them at this site, that talk back to 2 other ones back to another site
pd554801
interface port-channel9
  description *PD3750_Fiber01 network rack*
  switchport mode trunk
  speed 1000
  duplex full
  vpc 9
interface Ethernet1/4
  speed 1000
  duplex full
  channel-group 9
pd554802
  speed 1000
  duplex full
  vpc 9
  speed 1000
  duplex full
  channel-group 9
3750 switch config
interface Port-channel9
description *port channel to pd3750_Fiber_01*
duplex full
interface GigabitEthernet1/0/1
description *PD554801/p4 TRK*
channel-group 9 mode on
interface GigabitEthernet1/0/2
description *PD554802/P4 trunk port*
19 Replies 19
Gregory Snipes
Level 4
Level 4
I believe you need to use "channel-group 9 mode on" on the NX-OS side as well instead of the "channel-group 9" command you have.
i do have that , and have made sure, it will not show up on the nexus, if i go and put mode active it will show up, like this
  speed 1000
  channel-group 9 mode active
That's odd, I am using LACP on all my nexus port channels so they look the same as the IOS. I was not aware that the forced ones showed differently in the running config.
Could you provide the output of a "show port-channel summary" and a "show interface port-channel 9' for these devices. Also have you considered trying to change over to LACP on this? I find LACP port channels to be much more reliable and less finicky personally.
Also, could you provide the configuration of your VPC peer link and a "show VPC brief"?
port channel summary
1     Po1(SU)     Eth      NONE      Eth1/1(P)
6     Po6(SU)     Eth      NONE      Eth1/18(P)
8     Po8(SU)     Eth      NONE      Eth1/5(P)    Eth1/6(D)
9     Po9(SD)     Eth      LACP      Eth1/4(D)
20    Po20(SU)    Eth      NONE      Eth1/15(P)   Eth1/17(P)
101   Po101(SU)   Eth      NONE      Eth1/31(P)
102   Po102(SU)   Eth      NONE      Eth1/32(P)
sh int port chann 9  ( this will show down because i shut it down for know unitl i figure out how to configure it right )
PD554801# show interface port-channel 9
port-channel9 is down (Administratively down)
vPC Status: Down, vPC number: 9 [packets forwarded via vPC peer-link]
  Hardware: Port-Channel, address: 0000.0000.0000 (bia 0000.0000.0000)
  Description: *PD3750_Fiber01 network rack*
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
  reliability 9946/255, txload 1/255, rxload 1/255
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 1000 Mb/s
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  EtherType is 0x8100
  Members in this channel: Eth1/4
  30 seconds input rate 0 bits/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    165854 unicast packets  8645 multicast packets  4636 broadcast packets
    179135 input packets  97802516 bytes
    40900 jumbo packets  0 storm suppression bytes
    663 runts  0 giants  0 CRC  0 no buffer
    5332543433783378253 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    3576984 unicast packets  1107538 multicast packets  509810 broadcast packets
    5194332 output packets  3770989418 bytes
    659386 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  1 interface resets
and as for LACP, if it will fix it, the problem i have is there is noe clear documentation on wich is better ot the correct way to do them?  how would you do LACP correctly. this is the forst time i have ever worked on nexus switches with so many different commands, i have a basic concept but no way an expert, thank you
sh vpc brief
PD554801# sh vpc brief
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 20
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : failed
Type-2 consistency reason       : SVI type-2 configuration incompatible
vPC role                        : primary
Number of vPCs configured       : 102
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po20   up     1,3-4,9-12,16-18,20-22,30,64,68-69,100,113,150-154
                   ,156-167,173,180-184,187-192,197-200,218,226-227,2
                   49-250,260,295-297,301,320-326,351,600-601
vPC status
id     Port        Status Consistency Reason                     Active vlans
1      Po1         up     success     success                    1,3-4,9-12,
        16-18,20-22
        ,30,64,68-6
        9,100,113,1
        50-154,1....
6      Po6         up     success     success                    1,3-4,9-12,
        16-18,20-22
        ,30,64,68-6
        9,100,113,1
        50-154,1....
8      Po8         up     success     success                    1,3-4,9-12,
        16-18,20-22
        ,30,64,68-6
        9,100,113,1
        50-154,1....
9      Po9         down*  success     success                    -
101    Po101       up     success     success                    -
102    Po102       up     success     success                    -
102400 Eth101/1/1  down*  Not         Consistency Check Not      -
                          Applicable  Performed
102401 Eth101/1/2  down*  Not         Consistency Check Not      -
102402 Eth101/1/3  down*  Not         Consistency Check Not      -
102403 Eth101/1/4  down*  Not         Consistency Check Not      -
102404 Eth101/1/5  down*  Not         Consistency Check Not      -
102405 Eth101/1/6  down*  Not         Consistency Check Not      -
102406 Eth101/1/7  down*  Not         Consistency Check Not      -
102407 Eth101/1/8  down*  Not         Consistency Check Not      -
102408 Eth101/1/9  down*  Not         Consistency Check Not      -
102409 Eth101/1/10 down*  Not         Consistency Check Not      -
102410 Eth101/1/11 down*  Not         Consistency Check Not      -
102411 Eth101/1/12 down*  Not         Consistency Check Not      -
102412 Eth101/1/13 down*  Not         Consistency Check Not      -
102413 Eth101/1/14 down*  Not         Consistency Check Not      -
102414 Eth101/1/15 down*  Not         Consistency Check Not      -
102415 Eth101/1/16 down*  Not         Consistency Check Not      -
102416 Eth101/1/17 down*  Not         Consistency Check Not      -
102417 Eth101/1/18 down*  Not         Consistency Check Not      -
102418 Eth101/1/19 down*  Not         Consistency Check Not      -
102419 Eth101/1/20 down*  Not         Consistency Check Not      -
102420 Eth101/1/21 down*  Not         Consistency Check Not      -
102421 Eth101/1/22 down*  Not         Consistency Check Not      -
102422 Eth101/1/23 down*  Not         Consistency Check Not      -
102423 Eth101/1/24 down*  Not         Consistency Check Not      -
102424 Eth101/1/25 down*  Not         Consistency Check Not      -
102425 Eth101/1/26 down*  Not         Consistency Check Not      -
102426 Eth101/1/27 down*  Not         Consistency Check Not      -
102427 Eth101/1/28 down*  Not         Consistency Check Not      -
102428 Eth101/1/29 down*  Not         Consistency Check Not      -
102429 Eth101/1/30 down*  Not         Consistency Check Not      -
102430 Eth101/1/31 down*  Not         Consistency Check Not      -
102431 Eth101/1/32 down*  Not         Consistency Check Not      -
102432 Eth101/1/33 down*  Not         Consistency Check Not      -
102433 Eth101/1/34 down*  Not         Consistency Check Not      -
102434 Eth101/1/35 down*  Not         Consistency Check Not      -
102435 Eth101/1/36 down*  Not         Consistency Check Not      -
102436 Eth101/1/37 down*  Not         Consistency Check Not      -
102437 Eth101/1/38 down*  Not         Consistency Check Not      -
102438 Eth101/1/39 down*  Not         Consistency Check Not      -
102439 Eth101/1/40 down*  Not         Consistency Check Not      -
102440 Eth101/1/41 down*  Not         Consistency Check Not      -
102441 Eth101/1/42 down*  Not         Consistency Check Not      -
102442 Eth101/1/43 down*  Not         Consistency Check Not      -
102443 Eth101/1/44 down*  Not         Consistency Check Not      -
102444 Eth101/1/45 down*  Not         Consistency Check Not      -
102445 Eth101/1/46 down*  Not         Consistency Check Not      -
102446 Eth101/1/47 down*  Not         Consistency Check Not      -
102447 Eth101/1/48 down*  Not         Consistency Check Not      -
103424 Eth102/1/1  down*  Not         Consistency Check Not      -
103425 Eth102/1/2  down*  Not         Consistency Check Not      -
103426 Eth102/1/3  down*  Not         Consistency Check Not      -
103427 Eth102/1/4  down*  Not         Consistency Check Not      -
103428 Eth102/1/5  down*  Not         Consistency Check Not      -
103429 Eth102/1/6  down*  Not         Consistency Check Not      -
103430 Eth102/1/7  down*  Not         Consistency Check Not      -
103431 Eth102/1/8  down*  Not         Consistency Check Not      -
103432 Eth102/1/9  down*  Not         Consistency Check Not      -
103433 Eth102/1/10 down*  Not         Consistency Check Not      -
103434 Eth102/1/11 down*  Not         Consistency Check Not      -
103435 Eth102/1/12 down*  Not         Consistency Check Not      -
103436 Eth102/1/13 down*  Not         Consistency Check Not      -
103437 Eth102/1/14 down*  Not         Consistency Check Not      -
103438 Eth102/1/15 down*  Not         Consistency Check Not      -
103439 Eth102/1/16 down*  Not         Consistency Check Not      -
103440 Eth102/1/17 down*  Not         Consistency Check Not      -
103441 Eth102/1/18 down*  Not         Consistency Check Not      -
103442 Eth102/1/19 down*  Not         Consistency Check Not      -
103443 Eth102/1/20 down*  Not         Consistency Check Not      -
103444 Eth102/1/21 down*  Not         Consistency Check Not      -
103445 Eth102/1/22 down*  Not         Consistency Check Not      -
103446 Eth102/1/23 down*  Not         Consistency Check Not      -
103447 Eth102/1/24 down*  Not         Consistency Check Not      -
103448 Eth102/1/25 down*  Not         Consistency Check Not      -
103449 Eth102/1/26 down*  Not         Consistency Check Not      -
103450 Eth102/1/27 down*  Not         Consistency Check Not      -
103451 Eth102/1/28 down*  Not         Consistency Check Not      -
103452 Eth102/1/29 down*  Not         Consistency Check Not      -
103453 Eth102/1/30 down*  Not         Consistency Check Not      -
103454 Eth102/1/31 down*  Not         Consistency Check Not      -
103455 Eth102/1/32 down*  Not         Consistency Check Not      -
103456 Eth102/1/33 down*  Not         Consistency Check Not      -
103457 Eth102/1/34 down*  Not         Consistency Check Not      -
103458 Eth102/1/35 down*  Not         Consistency Check Not      -
103459 Eth102/1/36 down*  Not         Consistency Check Not      -
103460 Eth102/1/37 down*  Not         Consistency Check Not      -
103461 Eth102/1/38 down*  Not         Consistency Check Not      -
103462 Eth102/1/39 down*  Not         Consistency Check Not      -
103463 Eth102/1/40 down*  Not         Consistency Check Not      -
103464 Eth102/1/41 down*  Not         Consistency Check Not      -
103465 Eth102/1/42 down*  Not         Consistency Check Not      -
103466 Eth102/1/43 down*  Not         Consistency Check Not      -
103467 Eth102/1/44 down*  Not         Consistency Check Not      -
103468 Eth102/1/45 down*  Not         Consistency Check Not      -
103469 Eth102/1/46 down*  Not         Consistency Check Not      -
103470 Eth102/1/47 down*  Not         Consistency Check Not      -
103471 Eth102/1/48 down*  Not         Consistency Check Not      -
I cannot glean a whole lot of info about why it is not working as configured with it in the shutdown state. If you are open to the idea I would definitely recommend trying LACP.
LACPs main advantage over static port channeling is intelligence, LACP will communicate with the other side and make the best connection possible. With a static ether channel, if everything is not perfect you are pretty much hosed.
great thanks, i will put LCAP witch is active, do i need to also put that on the 3750 side as well?
Yes, both side will need to be set to LACP. I always like to set one side to active and one side to passive when I configure them, but you could also set both sides to active.
do you gain anything by putting one side active and the other passive?
I just like to know where the initiation is originating, no scientific reason for it or anything.
ahhh great thanks, i will try this and let you know the out come, next monday is when i can try it again, i will let you know, so if i were to put active and passive, the passive would be on the 3750 side correct?
Doesn't matter which one is the active side, do whatever makes sense to you.
ok, thanks, i will let you know how things go when i turn on the switch again, thank you
