09-15-2015 12:14 PM - edited 03-08-2019 01:47 AM
Hi There,
Our customer has two Nexus 5548 with L3 daughter cards (N55-D160L3-V2) but the module shows as offline.
The base license is not installed so I think this is the issue.
How do I get a new license pkg documents to apply the licenses to these two Nexus 5K as the document can not be found anywhere.
Alberto
09-15-2015 12:18 PM
Talk to your Cisco representative.. They can probably help you to get your PAK and license keys, if you bought them.. Normally the base licenses are included with the switch.. Can you please send us the "show license" output ?
Layer 3 Base License
The Layer 3 base license (N55-BAS1K9) is included with the Cisco Nexus 5500 Platform switch. The license provides the following support:
Connected, Static, RIPv2, OSPF (256 Dynamically Learnt Routes), EIGRP-Stub, HSRP, VRRP, IGMPv2/3, PIMv2, RACLs, uRPF
Layer 3 LAN-Enterprise License
The Layer 3 LAN Enterprise license (N55-LAN1K9) includes the following:
•All base license features
•Full EIGRP
•Unrestricted OSPF routes
•BGP
•VRF-Lite
09-15-2015 12:25 PM
Thanks for replaying,
it does not show anything on the output for "sh license".
and the "sho license usage" all licenses appear as not installed / unused.
sh license usage
Feature Ins Lic Status Expiry Date Comments
FCOE_NPV_PKG No - Unused -
FM_SERVER_PKG No - Unused -
ENTERPRISE_PKG No - Unused -
FC_FEATURES_PKG No - Unused -
VMFEX_FEATURE_PKG No - Unused -
ENHANCED_LAYER2_PKG No - Unused -
LAN_BASE_SERVICES_PKG No - Unused -
LAN_ENTERPRISE_SERVICES_PKG No - Unused -
So is there a way to get a new base license from Cisco?
Alberto
09-15-2015 12:46 PM
Can you please look at the inventory, and confirm the following outputs:
show inventory | inc L3
show system internal btcm info
09-15-2015 01:25 PM
system: version 5.2(1)N1(4)
sh inv | inc L3
NAME: "Module 3", DESCR: "O2 Daughter Card with L3 ASIC"
PID: N55-D160L3-V2 , VID: V01 , SN: FOC18039776
for the second command it does not work .. I tried and it does not have show system internal btcm ...
Alberto
09-15-2015 01:57 PM
Try this:
If you don't have the LAN BASE license listed above you will be hosed, to get a copy just go to www.cisco.com/go/licensing, click on get demo, nexus 5000 and then select LAN Base license, you will see it's a permanent license you can install.
Once you login to licensing page, next to the page where you put your PAKs, there is a drop down box. Choose demo license from that.. and select 5500..
It wiill look like this: | |
Cisco Nexus 5000/5500 Series | |
Your Nexus license is node locked to the Serial Number of the Nexus Chassis. Read More... | |
11-18-2015 04:35 AM
But nexus documentation says VRF-Lite is supported in base lisence...Could you please confirm?
Layer 3 Base Services Package LAN_BASE_SERVICES_PKG 19 |
N55-BAS1K9 |
Unlimited static routes and maximum of 256 dynamic routes. |
Layer 3 Enterprise Services Package |
N55-LAN1K9 |
N55-LAN1K9 includes below features in addition to the ones under N55-BAS1K9 license.
01-02-2025 06:18 AM
We are having the same problem, did you manage to find a solution to the problem?
