Difference between eap and eapol
palani2010
Level 4
Level 4
  • Difference between eap and eapol
2 Accepted Solutions
@palani2010
 The same thing but for EAP running in Local Area network is given the name of EAPOL (Extensible Authentication Protocol over LAN)
Endpoint- wlc/SW - ISE(AAA)
The endpoint send EAP encapsulate inside L2 frame so it called ""eapol""
Wlc/SW remove this encapsulate and add eap message to radius-request packet and send it to ISE(AAA)
So eap is packet for auth if it encapsulate inside L2 frame it called eapoL
MHM
@palani2010
Mark Elsen
 - Ref : https://support.huawei.com/enterprise/en/doc/EDOC1100086527
            Have a look at Table 1-3
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
MHM
Torbjørn
EAP is the authentication protocol itself while EAPOL is the way EAP is encapsulated for transmission over various LAN network types(ethernet, wireless ++)
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
