Nexus 5548 Link is operationally individual
Robert Wortmann
Hey,
we have 2 FlexPod (DC1 and DC2) with two Nexus 5548 on each side. We connected each Nexus on DC1 with the one on DC2 with 2 ports (Ethernet 1/21,1/22) in the port-channel 15. All worked fine until the day one SFP module was broken and we changed it. After a few minutes we noticed that a few Esxi hosts weren't connected anymore. A "show interface ethernet 1/22" showed the state "Link not connected", the "show port-channel sum" showed this:
15    Po15(SU)    Eth      LACP      Eth1/21(P)   Eth1/22(D)
I also noticed a syslog:
2013 Jul 22 12:10:36 mez: %ETH_PORT_CHANNEL-4-PORT_INDIVIDUAL: port Ethernet1/22 is operationally individual
After a few minutes the port-channel was fully  up again and we could the Esxi hosts. Shutting down the ports and "no shutdown" them didn't work either.
But a few minutes later the old problem came up.
Now it changes between these two states every 15 minutes. I think it is a problem with the lacp channel, but the config seems fine. I hope you can help me - if you need any further information, just ask!
Regards Robert
5 Replies 5
Reza Sharifi
Have you tried deleting the portchannel and rebuilding it?
Also, are the links betwen the 5ks configured as vPC peer-link?
Can you post the portchannel and the physical ports configs?
Yes I also tried this - same result.
No they're just a normal vPC.
dc1-n5k-02:
interface Ethernet1/22
  description dc2-n5k-01
  shutdown
  switchport mode trunk
  channel-group 15 mode active
interface port-channel15
  description DC Connection
  spanning-tree port type network
  vpc 15
dc2-n5k-01:
  description dc1-n5k-02
  shutdown
  vpc 15
"Shutdown" is because of the disconnections of the ESXi Hosts.
Robert
I would look at whether your ESXi hosts are correctly configured for LACP bundling.
Kevin Dorrell
Luxembourg
I also checked this - ESXi are are configured correctly.
Robert
kdebrouw
Hi Robert,
Could you share the output of show lacp counters interface port-channel15?
If we would be seeing a lot of difference in the RX and TX of LACPDU's we can assume 3 things, either we're not receiving them and we have a link problem, they're getting dropped in the path towards the CPU by copp or rate-limiting on the asic or the CPU has not enough time to process them because we have another high priority process consuming cpu cycles.
Kristof
