Router 1841 will not do interVlan routing
wenqiz1989
I have a router 1841 and a swith Catalyst 3560, to set a router on a stick
I set up the vlans, 3 loopback interface with 3 networks, and truck ports in the swith, set up subinterface with fa 0/0 port in the router.  It seems the router will not route between vlans.  I can not ping the loopback addresss in the switch from the router, and I can not ping from the swith to the default gateway in the router.
PDid anybody encounter this kind of problems with router 1841
Thanks!
Hello Grace,
Remove the Loopback1, Loopback2 and Loopback3 from your 3560. You have configured them with IP addresses that overlap the addressing on your router's subinterfaces. Because of this, you have tricked your 3560 into believing that the entire networks 172.16.10.0/24, 172.16.20.0/24, 172.16.30.0/24 are connected to the Loopback intefaces while in fact, they are not. Your 3560 must not believe these networks are located on Loopback interfaces because it will never send the packets to the router.
Also, the configuration of the DHCP server should be done only on those devices that actually have direct IP connectivity with the networks they serve. Currently, because your 3560 switch behaves as a Layer2 switch with a direct IP connectivity only to Vlan100, the configuration of the DHCP server is misplaced. Correctly, it should be configured on the router because it is connected to all VLANs in question. Later, as you proceed, you will learn about DHCP Relay Agent service that allows you to put a DHCP server into a different network than the clients are, but let's not complicate things right now.
Best regards,
Peter
wenqiz1989
Here is my config on Router 1841:
Current configuration : 1357 bytes
! Last configuration change at 14:22:11 UTC Wed Jul 24 2013
version 15.0
hostname RT-test2
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
license udi pid CISCO1841 sn FTX1246Z0W4
redundancy
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 172.16.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 172.16.20.1 255.255.255.0
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 172.16.30.1 255.255.255.0
interface FastEthernet0/0.100
encapsulation dot1Q 100
ip address 172.16.100.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
router eigrp 1
network 172.16.0.0
network 172.16.10.0 0.0.0.255
network 172.16.20.0 0.0.0.255
network 172.16.30.0 0.0.0.255
network 172.16.100.0 0.0.0.255
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Here is the config on the swith:
Current configuration : 5163 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW-Server
no aaa new-model
ip subnet-zero
ip routing
no ip domain-lookup
ip dhcp excluded-address 172.16.10.1
ip dhcp excluded-address 172.16.10.200 172.16.10.254
ip dhcp excluded-address 172.16.20.1
ip dhcp excluded-address 172.16.20.200 172.16.20.254
ip dhcp excluded-address 172.16.30.1
ip dhcp excluded-address 172.16.30.200 172.16.30.254
ip dhcp pool Dhcp-Vlan10
   network 172.16.10.0 255.255.255.0
   default-router 172.16.10.1
ip dhcp pool Dhcp-Vlan20
   network 172.16.20.0 255.255.255.0
   default-router 172.16.20.1
ip dhcp pool Dhcp-Vlan30
   network 172.16.30.0 255.255.255.0
   default-router 172.16.30.1
ip dhcp-server 172.16.10.200
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Loopback1
ip address 172.16.10.201 255.255.255.0
interface Loopback2
ip address 172.16.20.201 255.255.255.0
interface Loopback3
ip address 172.16.30.201 255.255.255.0
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
switchport access vlan 10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
switchport access vlan 20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
switchport access vlan 30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
description trunk to router
switchport mode trunk
interface FastEthernet0/48
description trunk to SW-Client
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Vlan1
no ip address
shutdown
interface Vlan10
no ip address
interface Vlan20
no ip address
interface Vlan30
no ip address
interface Vlan100
ip address 172.16.100.2 255.255.255.0
ip default-gateway 172.16.100.1
ip classless
ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
Thanks in advanced!
Hello Grace,
Best regards,
Peter
Hi! Peter:
Thank you for all the help.  I removed all the loopbacks, and add ip helper-address to each subinterface in the router.  Now I can ping and get IP for my hosts now.
Thanks again!
Grace
