Nexus 5548 stuck in loader>
CiscoBro
The Nexus 5548 switch when reloaded prompts
loader>
I read a little on it and first step was to extract kickstart using TFTP.
I used my workstation to configure tftp server.
But i cannot ping the mgmt ip of Nexus from the workstation.
My workstation is win7.
Is there a way to bypass using TFTP.
Plugging in usb also does not help, as Nexus does not see it in loader prompt.
Note:-bootflash has nothing its clean.
Also can anyone give me axamples of boot tftp://............., commands examples, not the format but real examples.
What if my kickstart image is in C:\>, what command i use
boot tftp://10.1.1.12/n5000.bin    ??
or, what is the correct format, i dont have to specify path inside my pc?
will tftp running in my computer automatically searches the whole pc for that file?
confused...
Any help appreciated
Reza Sharifi
Try this link
https://supportforums.cisco.com/video/11931536/how-restore-cisco-nexus-switch-loader-prompt
ppalmerjr
I currently have this exact issue....no ping after configuring the mgmt0 from the loader prompt.  I haven't tried tftp yet and am guessing that ping doesn't work but tftp will?  Any information on this?
vikram_sarode
I have same issue, no resolution yet
