Nexus 5548 Support for 1G Connectivity
pauldzummo
Does anybody know of a confirmed release date for the NX-OS revision that supports 1G connectivity to the Nexus 5548.  The documentation says that 1/10G connectivity is supported on all 32 ports, but there is a disclaimer that states the code to support 1G connectivity will not be available until first quarter 2011.  That statement is a bit vague for my needs and 1G connectivity is a requirement for the initial deployment of the Nexus in the datacenter.  I may have to change the order to a 5010 if the NX-OS release date does not fall in line with our delivery/deployment dates.
dario.didio
Level 4
Level 4
Starting from the latest release, 5.0(3)N1(1), 1Gig SFP transceivers are now supported on N5548:
http://www.cisco.com/en/US/partner/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_5_0_3_N1_1/Nexus5000_Release_Notes_5_0_3_N1_1_1a.html#wp315289
Note that you should first configure your interface with
speed 1000
otherwise the transceiver isn't recognized.
HTH,
Dario
