04-20-2016 01:56 PM - edited 03-08-2019 05:26 AM
Hey all,
We're setting up our monitoring system and on-boarding their network equipment. We're using SNMP v2. Our monitoring system will use SNMP Walk to gather all the information about the device. All the devices that we've on-boarded successfully and working except our Cisco Nexus 5548UP data centre switches (core switches).
The first thing we noticed is that the issue was intermittent. But after doing some deeper analysis, we found that we can consistently pinpoint exactly when it's going to work and when it's not, almost down to the second.
This is the pattern I've seen: 15 seconds before the 5 minute mark, the SNMP will work for 1 minute. After that, it will stop working for around 4 minutes, then will work again for 1 minute, then stop working again for 4 minutes, then repeat and repeat.
Here's the details with timestamps of the pattern:
04:04:00 - SNMP Walk is not working
04:04:45 - SNMP Walk is successful
04:05:45 - SNMP Walk stops working
04:09:45 - SNMP Walk is successful
04:10:45 - SNMP Walk stops working
04:14:45 - SNMP Walk is successful
04:15:45 - SNMP Walk stops working
and so on....
I've already ensured that the SNMP host server configured using the VRF Default.
The version of NX-OS we're running is 5.2(1)N1(4)
I am thinking this is a bug because I've read so much about issues with SNMP and NX-OS. However I haven't been able to find one that matches this behaviour. Just wondering if anyone has come across this before and can offer some input. I will be opening a TAC case.
John
04-21-2016 11:41 PM
looks like CoPP prevents you to make so frequent SNMP request. You can try two things:
1. Configure bulk requests on your manageament software, since 'walk' is intensive operation
2. Change default CoPP on your Nexus to allow more SNMP requests (would not recommend, because you can overload your device's CPU)
5.2(1)N1(4) is ancient, schedule upgrade.
