Nexus 5596 QoS for Cisco Phones
jecker
I am deploying a pair of Nexus 5596's with 3750 POE switches in the closets.  I'm looking for a best practice as how to configure the Nexus 5596 to support proper QoS for EF at the core.
If there is a good doc on how to explain this, that would be great.  All the docs I find are just the command reference and not how it needs to be confgiured in this senario.
Thanks.
6 Replies 6
Oleksandr Nesterov
I'd suggest you to read config guide first - to understand principles of QOS on n5k platform - since it differs from other devices.
Here is the giude:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/qos/Cisco_Nexus_5000_Series_NX-OS_Quality_of_Service_Configuration_Guide_chapter3.html
And then you can read practical example, which may be heplful in your case:
http://www.netcraftsmen.net/resources/blogs/qos-on-the-nexus-5000-2000-part-1.html
HTH,
Alex
Hello, thanks for the reply, those article were very helpful.
I've come up with a configuration on my core 5548's so that it should prioritze voice traffic / EF on every port and give voice 30% of the bandwidth.  This policy is to ensure that any voice traffice traversing from the access layer 3750's through the Nexus will always be priortized.
class-map type qos match-any VOICE
  match dscp 46
  match cos 5
class-map type queuing QUEUING-COS5
  match qos-group 5
policy-map type qos VOICE-IN
  class VOICE
    set qos-group 5
  class class-default
    set qos-group 0
policy-map type queuing QUEUING-GLOBAL
  class type queuing QUEUING-COS5
    priority
    bandwidth percent 30
  class type queuing class-fcoe
    bandwidth percent 0
  class type queuing class-default
    bandwidth percent 70
system qos
  service-policy type qos input VOICE-IN
  service-policy type queuing output QUEUING-GLOBAL
Would you change anything?  Thanks for the help.
It hink they're quite good.
Matching traffic -> sending to qos-group -> applying queuing policy on exit.
you can easily modify them according to your network needs.
Cheers,
Alex
Great, thanks for the help.
On last question, how do I enable qos statistics for a policy map?  I have enabled it globally.  Thanks:
NEX1# show policy-map interface e1/1
Global statistics status :   enabled
Ethernet1/1
  Service-policy (qos) input:   VOICE-IN
   policy statistics status:   disabled
    Class-map (qos):   VOICE (match-any)
      Match: dscp 46
      Match: cos 5
      set qos-group 5
    Class-map (qos):   class-default (match-any)
      Match: any
      set qos-group 0
Use "show queuing interface eth x/y" instead.
"show policy map interface ..." is not supported in the current nx-os releases.
HTH,
Alex
