Nexus 5624Q - configuration does not match the port capability...
kramsdell
I've got a 5624Q that I need to trunk over to a 3850 via 1G SFP fiber for external connectivity.  I was told by presales that this could be done using a CVR-QSFP-SFP10G adapter with a GLC-SX-MMD installed into it and another GLC-SX-MMD installed into then 3850.
When I try to configure the port on the 5624Q with a speed 1000, I get the configuration does not match the port capability error.
Any ideas??
s01# show int e1/5 transceiver details
Ethernet1/5
transceiver is present
type is QSA
name is CISCO-DNI
part number is CAZADERO-R
revision is 03
serial number is DTY19XXXXXX
nominal bitrate is 0 MBit/sec
cisco id is --
cisco extended id number is 155
DOM is not supported
s01# show int e1/5 capabilities
Ethernet1/5
Model: N5600-24Q-12Q-FIX
Type (SFP capable): QSA
Speed: 40000
Duplex: full
Trunk encap. type: 802.1Q
Channel: yes
Broadcast suppression: no
Flowcontrol: rx-(off/on),tx-(off/on)
Rate mode: none
QOS scheduling: rx-(6q1t),tx-(1p6q0t)
CoS rewrite: no
ToS rewrite: no
SPAN: yes
UDLD: yes
MDIX: no
Link Debounce: yes
Link Debounce Time: yes
dot1Q-tunnel mode: yes
Pvlan Trunk capable: yes
TDR capable: no
FabricPath capable: yes
Port mode: Switched
FEX Fabric: yes
s01# show int sta
Port Name Status Vlan Duplex Speed Type
Eth1/1 -- connected 1 full 40G QSFP-40G-SR
Eth1/2 -- connected 1 full 40G QSFP-40G-SR
Eth1/3 -- sfpAbsent 1 half 40G --
Eth1/4 -- sfpAbsent 1 half 40G --
Eth1/5 -- notconnec 1 half 40G QSA
Eth1/6 -- sfpAbsent 1 half 40G --
Eth1/7 -- sfpAbsent 1 half 40G --
Eth1/8 -- sfpAbsent 1 half 40G --
Eth1/9 -- sfpAbsent 1 half 40G --
Eth1/10 -- sfpAbsent 1 half 40G --
Eth1/11 -- connected 1 full 40G QSFP-40G-SR
Eth1/12 -- connected 1 full 40G QSFP-40G-SR
Po100 -- connected 1 full a-40G --
Po111 -- connected 1 full a-40G --
mgmt0 -- notconnec routed auto auto --
Eth100/1/1 -- connected 1 full a-10G 1G/10G
s01# conf t
Enter configuration commands, one per line. End with CNTL/Z.
s01(config)# int e1/5
s01(config-if)# speed 1000
ERROR: Ethernet1/5: Configuration does not match the port capability.
7 Replies 7
I don't think they support 1Gig just 10/40 .Please check here for your switch,refer Table 3.Some more infor here too
***Please rate all the useful posts***
-Prabath
Hi Preranda,
Thanks for the info.  See that's the thing, the doc you reference above, does show my situation as an acceptable solution.
Table 8.       Cisco Nexus 5600 Platform 1 and 10 Gigabit Ethernet SFP and SFP+ Transceiver Support Matrix
Cisco SFP and SFP+
Description
CVR-QSFP-SFP10G
40GBASE QSFP to SFP+ and SFP adapter (QSA) for 1 Gbps (GLC-T, SX/LH), 10G-SR/LR/ER connectivity
GLC-T
1000BASE-T standard
GLC-SX-MMD
1000BASE-SX short wavelength; with digital optical monitoring (DOM)
GLC-EX-SMD
1000BASE-EX long wavelength; with DOM
GLC-LH-SMD
1000BASE-LX/LH long wavelength; with DOM
GLC-ZX-SMD
1000BASE-ZX long wavelength; with DOM
yes sort of misleading,there might be one or two models out 5600 platform that supports 1Gig transceivers.check the hardware support status with show interface.
the second output I've attached is a 10/40 GEM module again doesn't support 1G. There's a possibility that you may need to convert a group of ports but i highly doubt in this case.
You might want to log a TAC and get a definite answer for this
-Prabath
Thanks for the info.  This is what I see on the port with the sho int command;
s01# show int e1/5
Ethernet1/5 is down (Link not connected)
Dedicated Interface
Hardware: 40000 Ethernet, address: 8c60.xxxx.xxxx (bia 8c60.xxxx.xxxx)
MTU 1500 bytes, BW 40000000 Kbit,, BW 40000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is access
auto-duplex, 40 Gb/s, media type is 40G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped never
0 interface resets
While waiting around for TAC to get back to me, I discovered the breakout command.
Here's what I was missing.  I needed to use the following command;
interface breakout slot 1 port 7-12 map 10g-4x
Then I was able to set the speed on the port to 1000 and insert the CVR-QSFP-SFP10G adapter with a GLC-SX-MMD without incident.
good work..I assume you were able to establish the connectivity to your 3850 after setting to speed to 1000.
here I have N9K-M12PQ GEM which I tried set to 1Gig with the converter "CVR-QSFP-SFP10G" and " GLC-SX-MMD"  to just to test out,Had no luck with that .Seems like the architecture it bit different on what you've got there.
I'm glad you've got that going
-Prabath
Hi Preanda,
Yes, I got the link to come up and was able to trunk over to my 3850.
The only unfortunate side effect is I had to waste 5 additional ports on the 5k to make this work - i.e. I had to set all 6 of the ports to 10G instead of just one.
Not a show stopper for me since this is a lab environment, but I wouldn't be happy if I had additional FEX or other reasons to use the native 40g ports.
