Nexus 5672UP (7.1) netflow configuration
Vag
I have configured netflow as follows:
Nexus(config)# feature netflow
Nexus(config)# flow exporter NFAexporter
Nexus(config-flow-exporter)# destination 192.168.x.x
Nexus(config-flow-exporter)# source Vlan123
Nexus(config-flow-exporter)# transport udp 9996
Nexus(config-flow-exporter)# version 9
Nexus(config)# flow monitor NFAmonitor
Nexus(config-flow-monitor)# exporter NFAexporter
Nexus(config-flow-monitor)# record netflow-original
Nexus(config-flow-monitor)# exit
Nexus(config)#flow timeout 60
Nexus(config)# sampler Sampler
Nexus (config-flow-sampler)#mode 1 out-of 128
and applied it on several interfaces, including SVIs and physical interfaces
Nexus(config)# interface ethernet 2/1
Nexus(config-if)# ip flow monitor NFAmonitor input sampler Sampler
I use ManageEngine NetFlow Analyzer 10 for the flow analysis part and while I do get some traffic data, it seems to be off, showing way lower bandwidth utilization values compared to the real ones.
Any ideas why this is happening?
Ferzan Unlu
Hi Vag,
   Can you check that if your real traffic utilization is 128 times of utilization which manageengine shows?
   That is because of your sampling method.(1 of 128).
Ferzan Unlu
Hi Vag,
