12-03-2013 04:08 AM - edited 03-07-2019 04:54 PM
I have a current config of a nexus 5k with 3 Fex attached. I wish to add an additional FEX. Other than the standard Switchport mode FEX and FEX associate options, are ther any other things i need to consider before adding an additional FEX. I will just be gving it the next number in my FEx numbering sequence and provisioning a port channel and interfaces prior to connection of the new FEX.
Many thanks
Steve
Solved! Go to Solution.
12-03-2013 10:31 AM
That is correct. You can give the next number in seauance to the new FEX with a new portchannel interface number and the other commands you noted.
12-03-2013 10:31 AM
12-04-2013 01:32 AM
Thanks for the info,
that's what I was hoping.
Cheers
Steve
