Nexus 5K and ACL
Oleg Volkov
Dear Sirs!
I have some segment of my network (segment "A"), which need to be accessible from other segment (segment "B"), but reverse traffic must be flow only for sessions, which was be initialized from segment "B".
If the TCP traffic, I can use key - "established" in the ACL row.
But what can I do, if the UDP?
Reflexive ACL on the Nexus 5K is not available.
All this configuration, must be implemented on the Nexus 5596 with L3 card.
In the ASA terminology, I want make security level SVI interface for vlan segment "A" lower. Best will be use state full firewall, but Nexus 5500 is not a firewall :-(
Thank!
Helping seriously ill children, all together. All information about this, is posted on my blog
Jon Marshall
The short answer is you can't.
Unless you have reflexive acls which you say Nexus switches don't support then it's not possible because acls are not stateful so they check each packet in isolation.
The "established" keyword only works for TCP because of the connection flags which UDP doesn't have.
Sorry but you need a firewall if you want to control which side can initiate the connection.
Jon
Jon Marshall
Jon
Ashok Kumar
Hi Oleg Volkov,
Jon said correctly, you gonna need a firewall for such configuration.
A piece of suggestion, if you have any IOS device connecting to nexus & you're controlling access between them; & don't want to waste the firewall hardware just for this thing; You can use zone based firewall configuration on the IOS device & you would be able to achieve the same what you would have with a firewall.
Zone-Based Policy Firewall Design and Application Guide
http://www.cisco.com/c/en/us/support/docs/security/ios-firewall/98628-zone-design-guide.html
- Ashok
Please rate the useful post or mark as correct answer as it will help others looking for similar information
Hi!
Thanks for answer. But I in this VLAN, I have high traffic and my other devices very slow for this.
I try to determine UDP port range and allow only this range and TCP established.
