Nexus 5K inconsistency problem...
I have an issue in ma nexus 5k. the issue I have attached as screen shot also attached the full running conf of both 5k-1 and 5k-2. Also the connectivity map.
Please provide me the command to make STP port type same(network or normal) on both side. And from where I have apply like should I apply the command from each port or globally from config terminal.
Reza Sharifi
You posted the config from N5K1 and not N5K2
oops sorry... it was my mistake... and problem fixed... thx for the support.
