Nexus 5K NTP not syncing with server
I am using external NTP servers to set the time on my 5k's but the switch doesnt seem to be syncing....
show run | i ntp
ntp server 1.uk.pool.ntp.org
ntp server 3.uk.pool.ntp.org
ntp source-interface Vlan15
ntp logging
Total peers : 2
* - selected for sync, + - peer mode(active),Switchin
- - peer mode(passive), = - polled in client mode
remote local st poll reach delay vrf
=46.17.63.196 10.10.205.249 16 64 0 0.00000 default
=139.162.192.13 10.10.205.249 16 64 0 0.00000 default
# ping 46.17.63.196
PING 46.17.63.196 (46.17.63.196): 56 data bytes
64 bytes from 46.17.63.196: icmp_seq=0 ttl=46 time=11.424 ms
64 bytes from 46.17.63.196: icmp_seq=1 ttl=46 time=11.401 ms
switch cannot ping 1.uk.pool.ntp.org by dns..
balaji.bandi
Try ntp server 46.17.63.196
Do you have DNS Server configured in nexus 5K if not pelase configure, ping with DNS before it sync with NTP.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/system_management/502_n1_1/b_Cisco_n5k_system_mgmt_cg_rel_502_n1_1/cisco_n5k_system_mgmt_cg_rel_502_n1_1_dns.html
BB
marce1000
 - Possible DNS issue may also be confirmed by using an ip address from the mentioned ntp-pools instead, if that works, then look at DNS.
 M.
